I have chosen the Hooker Sidemounts.. headers & pipes-
Anybody have experience with these?
Installation Issues?
Problems?
Special parts needed?
I am not concerned about people touching the hot pipes.
If they're dumb enough to touch them, then they don't belong in or near my car.
(The pipes are for me, not for them.)
The only bad thing that I seem to have with the Hookers sides right now is there lack quality control. On the set that I purchased for my 69 big block I had problems with the drivers side not even coming close to bolting up. When I tried tightening down the header bolts the top inside header tube right before it went into the collector would hit the lower fender. The passenger side bolted right up with no problems. They sent me a new drivers side and it bolted up but I had to ding it in a number of areas still due to clearance issues. It still sits closer to the lower fender than the passengers side. Hooker moved its manufacturing to Mexico and I heard that since then quality control has gone down. I'm still PO about the way that the drivers side fits!!!!
Pray that you get a good set when you order them!!!!
Good luck!!!!
I have to agree, buy the Spiral Turbo Specialties inserts. They are a lot less restrictive than the Hookers and sound really nice. You might also consider buying the sidepipes from the same place. They mount a lot nicer than Hookers. You don't have to take off the rocker panels.
The flanges on the headers are made for the cast iron BB heads. The Gen VI aluminum head bolts stick up a little further, and the flanges need to be clearanced. Also, I had to ding a d/s header tube to clear the steering box.
Oh, yeah. DON'T buy Hooker's ceramic coating; it rusts in weeks! Get it done afterward, or buy the Hookers from Jet Hot....They'll sell 'em to you for about the same $$$$$, plus they'll be coated properly, inside AND out.
Plus, use the JCL baffles. The Hooker glasspacks cost me 95 hp on the dyno run- I'm NOT joking! BTW, use the set with the 2 1/8" primaries, too. All the stuff the other guys told you is right on the money.
My 2c.
:yesnod: :chevy :chevy :yesnod:
Re: Advice on Hooker Sidepipes needed... (MassVette)
Tom, Before you met me, had the black hooker side mounts:
Pros: They sound great
Less heat in the cockpit
Cons:
Fit: I had, and alot of folks have said, the fit is almost perfect, but not quite. Where the collectors come out the side, and come up against the floorboards, you have to grind just a little bit of the fibergalss side covers, just in the front near the wheel well
Upkeep: Pain in the butt. The black ones get sand blasted from the front wheels, and its a constant fight against rust. The chrome ones get beat up by the sand from the wheels as well. Rust really gets in the nooks/crannies where the headers snake together
