Dash Lights Not Working
Old Mar 1, 2018 | 10:23 PM
YeahDoggie's Avatar
YeahDoggie
Navigator
Default Dash Lights Not Working
Just picked up a 74 coupe and already having electrical issues. My dash lights do not work. I have read other threads and they mention the INST fuse (small fuse on the bottom). I do not have power to either side at any time. I have tried with the headlight switch in both "on" positions turned both directions and get nothing. The dash pad and gauges are currently out of it.
I believe the INST fuse should only have power when the headlight switch is on.
Could a bad headlight switch be the problem? Is there a way to test it? Should all the wires coming off of the switch have power when it is pulled on?
The headlights also do not pop up when I turn them on (they do light up though), but I figured there was issues with the vacuum system (currently working on that too).
Old Mar 1, 2018 | 10:37 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and Welcome!
The 'tail light' fuse feeds the instrument fuse so see if the tail light fuse is good.
While you are under there check the gauges fuse.
Here's a head light vacuum guide:
http://www.corvette-101.com/vacuum.htm
Old Mar 1, 2018 | 10:49 PM
sparky77's Avatar
sparky77
Best way to trouble shoot an electrical problem is to get a wiring diagram and start at the source ,fuse ,battery . and with a tester trace the circuit until you find the fault .It is not a good idea to trouble shoot by just changing parts that may fix the problem but it might cost you alot of time and money.
To answer you're question it could be the headlight switch or a bad wire or a connector somewhere in the circuit.
Old Mar 1, 2018 | 10:54 PM
YeahDoggie's Avatar
YeahDoggie
Navigator
Thanks for the quick replies.
Is there a good source online for Vette wiring diagrams? Or is my best bet to locate a booklet?
Old Mar 1, 2018 | 10:55 PM
Peterbuilt's Avatar
Peterbuilt
https://docs.google.com/viewer?a=v&p...TRkNTFkY2E0NmM
Old Mar 1, 2018 | 11:04 PM
YeahDoggie's Avatar
YeahDoggie
Navigator
You...are the MAN!
Old Mar 2, 2018 | 09:13 AM
C376FL's Avatar
C376FL
The way I read your post the dash is out of the car. If the lights are just hanging there, they are not grounded. they need to be pluged into the dash and the ground needs to be hooked up to the back of the metal part of the gauges. That is where you get ground. The metal prongs of the light sockets is how they get their ground.
Last edited by C376FL; Mar 2, 2018 at 09:19 AM. Reason: first you need to see why you have no power to the fuses
Old Mar 2, 2018 | 11:47 AM
YeahDoggie's Avatar
YeahDoggie
Navigator
Good catch.
I should have clarified that the dash lights were not working when the dash was installed. I was using a test light to check for power at the wires.
Interestingly enough, I was messing with the switch again last night and they started working all of a sudden. The switch is old but perhaps the repeated twisting and pulling got something working.
To Dash Lights Not Working
