which thermostat ?
Old Oct 14, 2002 | 07:10 PM
OkeeGuy's Avatar
OkeeGuy
Default which thermostat ?
the new engine will have a new Performer intake so i will be buying a new gooseneck...
seems like a good time to replace the thermostat...
should i go with a 185* ?
Old Oct 14, 2002 | 07:14 PM
Paul L's Avatar
Paul L
Default Re: which thermostat ? (SIGNGUY)
Go with this. A superior product. Don't let the 195F scare you; 1979s were designed to run at that temp.
Old Oct 14, 2002 | 08:02 PM
vettfixr's Avatar
vettfixr
I run a 160 thermostat in my 74 and I like it. Without the AC on it will run at 160 all day in any weather including high 90 degree days. With the AC on it runs about 180 - 195 on hot days. I like the extra margin of cooling that the lower thermostats give. JMHO.
Old Oct 14, 2002 | 08:03 PM
Turbo-Jet's Avatar
Turbo-Jet
OEM spec is the always the best choice. More effiecent, lower emissions, less engine wear.
Old Oct 14, 2002 | 08:11 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: which thermostat ? (Turbo-Jet)
The high temp stat is purely for emissions. 160 is a little low for my taste (it doesn't get that hot here). I always ran a 180 stat with no problems.
Paul, is that the kind of stat that goes into the open position once it fails?
I have this for a thermostat (my radiator only has AN bungs)
It has a nice bypass to maintain coolant flow even when the stat is closed.
Marck
[Modified by Twinnie, 6:13 PM 10/14/2002]
Old Oct 14, 2002 | 08:18 PM
Paul L's Avatar
Paul L
Default Re: which thermostat ? (Twinnie)
I do not know. It did solve problems of going to 220F in summer heat, now long gone. It is incredibly stable at 195F. And that is what I wanted for my stock engine. Cannot ask for more! Here is my experiment of last summer.
http://forums.corvetteforum.com/zerothread?id=366876
[Modified by paul79, 7:24 PM 10/14/2002]
Old Oct 14, 2002 | 11:06 PM
73 LS-4's Avatar
73 LS-4
My personal preference is a 180, it's a good compromise temp.
:cheers:
Pat Kunz
Old Oct 15, 2002 | 09:49 AM
1LE's Avatar
1LE
I have a 195 in my 74, I runs 195-200 all day long.
Old Oct 15, 2002 | 10:03 AM
jerryp58's Avatar
jerryp58
I bought a Stant 180 for my '77.
I wasn't too concerned about the rating because I figured I'd be up at about 195 no matter what (160, 180, or 195) and that's where it runs.
What I did hope to get, and had absolutely NO LUCK finding, were these, hi-flow, fail in the open position, thermostats . I asked all around, and everyone looked at me like I was an idiot (well, that may be for other reasons :rolleyes: ).
Anyway, if you can find a hi-flow, fail in the open position (I know they've referred to them on TNN car shows), I think that'd be the way to go :yesnod:
Good Luck & let us know what you use and how you like it (thermostats seem to be a really popular item here).
Fevre's Avatar
Fevre
Default Re: which thermostat ? (73 LS-4)
:cheers:
Pat Kunz
Me too!
:yesnod: Good for all around and all year driving. The 160 did not give me enough heat when driving on a cold day.
Old Oct 15, 2002 | 04:06 PM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: which thermostat ? (Fevre)
:cheers:
Pat Kunz
Me too!
Do you guys realize a hotter running engine is more thermodynamically efficient (ie more power)? In a heat cycle, energy transfer comes from delta T.
Old Oct 15, 2002 | 04:18 PM
Fevre's Avatar
Fevre
Then should I let my car get to 300? :D
Seriously though, in your opinion what is the optimal temp? Other than the the lubrication problem, I would think colder is better since cooler air holds more O2 allow for greater combustion.
Old Oct 15, 2002 | 04:23 PM
Turbo-Jet's Avatar
Turbo-Jet
Factory spec is best. Yes, colder intake air is good, to further increase delta T. This is a compromise that must be made, as a hot engine will inadvertently warm the incoming air charge.
[Modified by Turbo-Jet, 12:24 PM 10/15/2002]
Old Oct 15, 2002 | 04:25 PM
vettfixr's Avatar
vettfixr
Yes, but my old body isn't thermodynamically efficient and sitting behind an engine that's running 220 degrees in the summer isn't my idea of fun. I like my car to run cool so I run a 160 thermostat but that's my preference. Most people would probably be more comfortable with a 180. I don't see the advantage of going higher than that. Besides, how efficient can a 25 or 30 year old engine be that still uses a carb.
Old Oct 15, 2002 | 04:36 PM
Fevre's Avatar
Fevre
But most of us are not running factory spec cars. Probably not much diff either way.
To which thermostat ?
