big block 427 dieseling
Old Mar 11, 2018 | 01:24 AM
ddtully's Avatar
ddtully
Default big block 427 dieseling
What is the best way to correct dieseling on a big block chevy motor. I'm seeing many various option on this forum that I am not certain is the best answer. Thanks!
Old Mar 11, 2018 | 10:16 AM
gkull's Avatar
gkull
Let's start with the easy stuff. Could you please pull out one of the rear most plugs and tell us that part number and take a picture of the tip
Old Mar 11, 2018 | 12:16 PM
PAmotorman's Avatar
PAmotorman
run some GM top engine cleaner to remove the carbon from the pistons that is glowing red hot.
Old Mar 11, 2018 | 03:32 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Check your idle timing and idle speed. A simple first step that costs you nothing but your time.
Old Mar 11, 2018 | 03:54 PM
HeadsU.P.'s Avatar
HeadsU.P.
Secondary throttle plate not closing far enough.
Old Mar 12, 2018 | 12:53 PM
MelWff's Avatar
MelWff
Default Carburetor?
Originally Posted by HeadsU.P.
Secondary throttle plate not closing far enough. Should be set at 0.020 gap on the butterfly / transition slot.
Why would you make that statement without first asking what type of carburetor, Holley, Quadrajet, Edelbrock?
Old Mar 12, 2018 | 12:57 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
op ran 2 threads.
timing was wrong, fixed
to those that keep making more than one thread,
take note
To big block 427 dieseling
