Testing windshield wiper door actuator valve???
Old Mar 12, 2018 | 02:44 PM
Cigars4me's Avatar
Cigars4me
Default Testing windshield wiper door actuator valve???
1972 Vette, can anyone tell me how to test the w/s wiper door actuator valve that bolts to the firewall? Want to be sure it's good before I get too far in the rebuild process. There is no engine in the car so I can't use the vacuum from the engine to test it. Thanks for your help, Bob
Old Mar 12, 2018 | 03:40 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
hand squeezed vacuum pump sold as brake bleeder
at places like harbor freight. 25 bucks.
Old Mar 12, 2018 | 03:57 PM
Alan 71's Avatar
Alan 71
Hi ZO6,
I'm not sure what part you're referring to because of.... "bolts to the firewall'.
The actuator itself?
The actuator relay?
The wiper door 3 Port Interlock Switch?
There's a test process for each of them but each is a little different.
Regards,
Alan
Actuator:
Actuator Relay:
3 Port Interlock Switch:
Old Mar 12, 2018 | 08:56 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There are two videos on youtube on how to do this.. one is wrong.. ours is 100 percent correct. Testing the valve should always be done on the middle tit on the valve, not the lower. When the valve is open (arms up and working) the valve should block vacuum on the lower port. When the arms park the vacuum should pass from the middle tit to the lower one. Testing on the lower tit for blocking vacuum, we'll its just not smart. If you look at the vacuum schematic you'll see that the pulling vacuum comes in on the middle tit and has to be blocked from the lower to function properly. It's possible for a valve to block on the lower tit and still leak vacuum on the upper.... this is the main reason the imported wiper valves are junk... they block but leak.
Actuator testing:
Willcox
69-72 Wiper Arm Vacuum Relay testing.
Old Mar 12, 2018 | 10:30 PM
Hammerhead Fred's Avatar
Hammerhead Fred
The large actuator (top photo posted by Alan) is easily tested without any tools. Simply remove both hoses, put your finger over one of the hose connectors, then attempt to move the piston rod (easier to do on the bench but can be done in the car by manually raising the wiper door using your hand). If it moves while you have the hose connector covered/plugged then the actuator is bad. If it won't move unless your remove your finger from the hose connector then it's good. It's just a big diaphragm with an opening on either side.
To Testing windshield wiper door actuator valve???
