68 Lower Column Bearing
Old Mar 16, 2018 | 04:42 PM
Tyrel B's Avatar
Tyrel B
Default 68 Lower Column Bearing
I have removed the column on my 68, non tilt, non power. I have the lower bearing out now, but am having a hard time finding the correct replacement. The lower bearing I have has ball bearings inside of it. It wasn't "shot" but was fairly rusty and rolled rough. I had most of it torn apart to replace the turn signal cam and also to replace the steering gear and rag joint, so i figured I'd do it while I was there. Hopefully not a bad choice....Its wet with PB Blaster just FYI.
The Red line showers where I can see the roller bearings
The Yellow line is where I separated the lower bearing from the column
Old Mar 16, 2018 | 05:15 PM
twinpack's Avatar
twinpack
I replaced mine a couple years ago. I think it was a needle bearing. The original was ball like yours. I'm pretty sure I bought mine from Paragon Corvette. You could also try Dr. Rebuild. I have had good luck getting NOS and correct part from him lately.
Old Mar 16, 2018 | 06:18 PM
carriljc's Avatar
carriljc
try searching for: OEM Part Number 7800407 BEARING
Below is a link to a couple of places... but you can search around to see if you can find a better price.
https://willcoxcorvette.com/steering...g-lower-67l-68
https://www.paragoncorvette.com/p-35...r-bearing.aspx
Old Mar 16, 2018 | 06:34 PM
682XLR8's Avatar
682XLR8
This is the one I installed on my 68 column
Old Mar 16, 2018 | 07:45 PM
Tyrel B's Avatar
Tyrel B
Awesome, If the needle bearing style will work, that's just fine with me. Thanks again for all the help.
Old Mar 17, 2018 | 02:53 AM
terrys6t8roadster's Avatar
terrys6t8roadster
When the lower brg failed on my 6t8, and after getting the wrong bearing I went and got a oilite bronze bushing [about a inch in length] from a local bearing house. That was 10 years ago and still no play. T
Old Mar 17, 2018 | 12:17 PM
carriljc's Avatar
carriljc
That's probably an even better idea....
Old Mar 17, 2018 | 12:36 PM
Tyrel B's Avatar
Tyrel B
Any idea where to get one online? There are no "local bearing houses" around me. Kind of in BFE. I like the idea of using a oilite bronze bushing too if it's easy to obtain.
Old Mar 17, 2018 | 07:42 PM
carriljc's Avatar
carriljc
According to the Oilite website the nearest distributor to Phillipsburg KS is in Kearny NE.
https://oilite.com/distributors
Unless you know the exact one you need...I'd go to the distributor to get one.....not sure how to determine which one you need, unless you can eyeball them.
Old Mar 18, 2018 | 12:13 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I ended up buying a plain bronze bearing/bushing from Home depot or Lowes. Since they didn't stock the correct length bearing I bought a longer one and cut it to length. I put plenty of grease above the bearing so it could work it's way down over the years. I also applied silicone sealer to the bottom of the column where the shaft exited so water could not enter as it did with the original bearing......3 years and smooth as can be.
You can order a sealed ball bearing or needle bearing for about $15.00 from a bearing warehouse/store.
To 68 Lower Column Bearing
