Consensus on axle snap ring
Old Mar 16, 2018 | 07:30 PM
Dusky's Avatar
Dusky
Default Consensus on axle snap ring
Hi!
Whats the consensus on the use of the axle snap rings? Ive seen people say theyre absolutely needed ( and a very scary video shown too!)
And others say they would never use Them and GM only used Them to prevent the axles from dropping out.
The previous owner was clearly in 2 minds as well, as he only fitted 1 ring. (No signs thrrr were 2 clips and 1 popped off)
Cheers
Old Mar 17, 2018 | 02:56 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Stock rear suspension they are required. T
Old Mar 17, 2018 | 08:20 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Can anyone provide any documented event of a side axle falling out of the differential while the car is in motion? I can visualise them falling out on the assembly line without the clip.
Old Mar 17, 2018 | 10:37 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
I don't think falling out is a possibility but 1/4 to 1/2 in and out movement is and that can allow the car to really move around.
GM put them there for a reason, unless you have added a top link I would not run without them.
There have been plenty of owners pull the rear end apart and the clips are laying in the bottom of the diff or completely gone with no issues.
Why take the chance if your in the diff adding the clips is not an issue,
I'm no expert on this so this is really just my thoughts,
Neal
Old Mar 17, 2018 | 10:59 AM
Dusky's Avatar
Dusky
Neal
Finding a second one is though I cant find any. Only find them for the dana 44, but a 79 rear end is a dana 36 afaik?
cheers
Old Mar 18, 2018 | 05:20 PM
Dusky's Avatar
Dusky
What strenght / din grade do these need to be?
Old Mar 19, 2018 | 03:03 PM
TCracingCA's Avatar
TCracingCA
I have c-clips in two cars and putting them in the third! The fourth still has snap rings! To prevent movement, I would never go without them!
To Consensus on axle snap ring
