Rear End Ratio
Old Oct 15, 2002 | 08:39 PM
Bullyj's Avatar
Bullyj
Default Rear End Ratio
At 55mph I turn 3000 rpm does anybody have an idea as to what my rear end ratio might be. (stock 350 180hp stock turbo 350)
Old Oct 15, 2002 | 08:44 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: Rear End Ratio (Bullyj)
that sounds high for 3.55s, but thats possible. at 60-65 im doing 4000RPM and i have 4.11s(not factory)
Old Oct 15, 2002 | 08:48 PM
67HEAVEN's Avatar
67HEAVEN
Don't forget tire diameter relative to original.
Old Oct 15, 2002 | 09:17 PM
GaryS's Avatar
GaryS
Take a look at the following web site:
http://www.idavette.net/tech/ratioc.htm
I used 26" for the tire diameter. Pretty accurate.
Gary
Old Oct 15, 2002 | 09:25 PM
Bullyj's Avatar
Bullyj
Default Re: Rear End Ratio (GaryS)
Running 225 70 15 I think it's 26.5 diameter
Old Oct 15, 2002 | 09:42 PM
Schmucker's Avatar
Schmucker
I've got the same car and I have 3.55's factory. All the L48's had 3.55's for '77, L82's could come with 3.70 gears. So someone swapped your gears at some point, probably to 3.73s or 3.90s. I turn 3200rpm at 70mph. 245/60R15 tires.
[Modified by Schmucker, 7:43 PM 10/15/2002]
Old Oct 15, 2002 | 09:51 PM
Bullyj's Avatar
Bullyj
Default Re: Rear End Ratio (Schmucker)
I turn 3750 at 70 mph
Old Oct 15, 2002 | 09:54 PM
Bullyj's Avatar
Bullyj
I used the calculator that gary had it said 4.11
Old Oct 15, 2002 | 10:26 PM
Paul L's Avatar
Paul L
I would say that you have a 3.55:1. Here is mine at about 70mph (converted from metric).
Old Oct 15, 2002 | 10:58 PM
ZL1powr's Avatar
ZL1powr
For future reference you can use the following equation to compute Rear End ratio:
Rear Ratio = (D*RPM)/(336.14*Speed)
where D is tire diameter in inches and Speed is in MPH
This assumes the transmission gear is 1:1 i.e. 4th gear in a 4 spd. Otherwise the above formula gives you the product of the rearend ratio and the transmission gear ratio. I get 4.3 for D=26.5, RPM=3000 and Speed=55.
Old Oct 16, 2002 | 01:53 PM
Turbo-Jet's Avatar
Turbo-Jet
Look at the code stamped onto bottom face of the diff case.
To Rear End Ratio
