Tach drive distributor repair kit
Old Apr 1, 2018 | 09:42 AM
JWindsor's Avatar
JWindsor
Default Tach drive distributor repair kit
I’ve got ‘73 tach drive distributor. If I spin the cable the tach moves, if I spin the rotor the tach doesn’t move. I’ve read on here that others have bought cross gear repair kits and the quality hasn’t been great or that they’ve had to modify parts. Is there a kit that somebody has bought that didn’t need modifications? If so, where did you buy it?
Old Apr 1, 2018 | 09:52 AM
lars's Avatar
lars
It's not a matter of kit quality. It's a matter of repairing the distributor housing itself. The crossgear and mainshaft strip out and fail when the housing thrust surface gets hogged out and damaged. You have to do a proper machine repair of the housing and install a new thrust surface before installing any bolt-in parts.
Lars
Old Apr 1, 2018 | 09:59 PM
Big2Bird's Avatar
Big2Bird
Lars
Old Apr 1, 2018 | 11:15 PM
redvetracr's Avatar
redvetracr
Lars
shouldn`t a `73 distributor have a factory installed plastic button?
Old Apr 1, 2018 | 11:20 PM
JWindsor's Avatar
JWindsor
I haven’t gotten into the distributor yet. Is the plastic button better? I’ve read that there’s a few different styles of these distributors. Is the ‘73 distributor good or worse then the earlier version?
Old Apr 2, 2018 | 10:14 AM
lars's Avatar
lars
If your distributor has the hole for the nylon thrust button, and if there is no damage to the distributor housing cast iron surface, you can use the plastic thrust button available from Long Island Corvette:
https://www.parts123.com/parts123/yb...Z5Z5Z50000370a
These work well, but only if the housing surface is undamaged.
Lars
Old Apr 2, 2018 | 08:52 PM
Big2Bird's Avatar
Big2Bird
Lars
That's cheap. I have been buying all the NOS GM buttons I can find. I'd like to save them for purists if those are okay.
Old Apr 2, 2018 | 08:56 PM
lars's Avatar
lars
Those original nylon buttons are the best. GM finally got the thrust surface thing figured out in the last couple of years of tach drive distributors. Buy every one of those you can find!
Lars
Old Apr 2, 2018 | 09:06 PM
Big2Bird's Avatar
Big2Bird
Lars
Good to know.
To Tach drive distributor repair kit
