81 corvette ecu issues??
Old Apr 1, 2018 | 02:58 PM
hari151's Avatar
hari151
2nd Gear
Default 81 corvette ecu issues??
Hi
I'm new to the site and have some issues with my 81 corvette that i just purchased months ago. The ECU doesn't look like its from a 81 and looks as if it was modified, no check engine lights come on.....I'm attaching pics, it looks like a GM ecu but pics ive seen for 81 look different .....please advise would appreciate it...
Old Apr 1, 2018 | 04:50 PM
Tim81's Avatar
Tim81
Not sure what that is but it sure doesn’t look like the end I have in my 81. Where was that mounted at? The eco or ccc is mounted on the battery compartment wall in front of the battery.
Old Apr 1, 2018 | 04:52 PM
Tim81's Avatar
Tim81
Ecm or CCC. Sorry about the spell check
Old Apr 1, 2018 | 05:19 PM
Tim81's Avatar
Tim81
here is what mine looks like.
Old Apr 1, 2018 | 07:19 PM
Big2Bird's Avatar
Big2Bird
I think your holding the alarm module.
Old Apr 1, 2018 | 09:09 PM
hari151's Avatar
hari151
2nd Gear
Im not sure its located in the box next to the battery with 2 other relays next to it...i have the car apart and doesnt seem there is no other computer.....so maybe it was converted to manual running......i do have the dash apart so this module i believe is whats running it....does someone have a pic of the alarm module ??
Old Apr 1, 2018 | 09:30 PM
Big2Bird's Avatar
Big2Bird
Your holding one.
Old Apr 2, 2018 | 01:53 AM
Tim81's Avatar
Tim81
If someone took the computer out then hopefully they changed the carb and distributor too. Take a picture of the top of the carb and we’ll be able to tell if the computer is still in there.
Old Apr 3, 2018 | 04:15 AM
Antz81's Avatar
Antz81
I agree. If there's nothing in front of the battery, then post a pic of the car and distributor. They need to be changed if the Ecu is gone. Would also expect the wiring for it to still be in place
Old Apr 3, 2018 | 07:41 AM
Engage's Avatar
Engage
Hi
If you need one I have one for an 81 with auto trans
Old Apr 3, 2018 | 10:56 AM
Big2Bird's Avatar
Big2Bird
Actually, the carb will work just fine unplugged. It leans out the mixture when running the ecm, and works just fine unplugged. Install a 4 pin HEI and run it.
Old Apr 3, 2018 | 06:17 PM
av81's Avatar
av81
look at the battery , in front of it against the wall its tucked under there.
To 81 corvette ecu issues??
