Can you recognize this part/line?
Apr 2, 2018 | 12:36 PM
1970 454 Auto Transmission
The only line I did not label when I removed the engine and auto transmission 2 years ago. I want to replace the rubber parts, so can any one identify it so I can order?
Kind regards
Paul
Apr 2, 2018 | 12:45 PM
Vacuum modulator line from manifold to transmission
Apr 2, 2018 | 01:00 PM
Many thanks CF
Kind regards
Paul
Apr 2, 2018 | 01:27 PM
Quote:
Originally Posted by
PBCloud
Many thanks CF
Kind regards
Paul
I also concur, just had to do mine
Apr 2, 2018 | 01:35 PM
Make sure you get proper vacuum hose and not just regular hose.
Check the ends on the steel line, should look vaguely like this
The rubber line down at the transmission has a 90 deg bend formed in it, can't really take a straight line and bend it as it will kink closed.
M
Apr 3, 2018 | 03:36 AM
Mooser
M
Many thanks Guys.
Apr 3, 2018 | 03:37 AM
That is very clear many thanks for your responses.
Kind regards
Paul
Apr 3, 2018 | 10:27 AM
Speaking of vacuum modulator lines . . . .
Is there any purpose for the top end of the steel line to be reduced in size, (two times) like it is?
Apr 3, 2018 | 06:19 PM
All things being equal it will react to a change in the vacuum faster than if the pipe was all the same size.
It also makes the rubber hose fit nicer
M
Apr 3, 2018 | 06:34 PM
Double posted again Arrrrggg
M
