74 BB Heat Riser Cleaning Question
Old Mar 31, 2018 | 02:43 PM
74VetteAZ's Avatar
74VetteAZ
Default 74 BB Heat Riser Cleaning Question
Can this part be cleaned in a parts washer??
- just wanted to make sure/Thanks!!
Old Apr 1, 2018 | 08:32 PM
Sayfoo's Avatar
Sayfoo
Yes, it's all cast iron and steel. BUT, a parts washer is mostly for grease, oil, etc. I don't think it will do much if it's has hard crud inside.
Might smoke a bit if you don't get all the solvent off.
Old Apr 2, 2018 | 01:01 AM
7T1vette's Avatar
7T1vette
Since you are in AZ, I would highly recommed that you cut the heat riser valve off its shaft before you reinstall it to the car. That device is only needed in cold environments; and, if it were to lock up from rust in the 'closed' position, you can easily damage the engine. I cut mine out years ago and haven't had any significant problems...and I live in TN.
Old Apr 2, 2018 | 01:45 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Get rid of it as you will have problems.
I purchased a blank spacer for the passenger side.
I'm running stock manifold straight through to muffler no riser or smog stuff.
In extreme cold as 7T1 said it would retract to closed position like the choke.
Hot air would be transferred back through the intake manifold to warm the fuel and engine.
When they were daily drivers in Detroit it had a purpose.
Marshal
Old Apr 3, 2018 | 10:56 AM
74VetteAZ's Avatar
74VetteAZ
Thanks for all the valuable advice - much appreciated!
Old Apr 3, 2018 | 07:51 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
I cut the butterfly valve out of mine too. Looks stock on the outside, but no restriction inside.
Next are the Felpro intake gaskets that block off the exhaust crossover in the intake manifold.
To 74 BB Heat Riser Cleaning Question
