Brake caliper leak again
Old Apr 5, 2018 | 05:31 PM
The Punisher's Avatar
The Punisher
Default Brake caliper leak again
After 3 years I have a o-ring brake caliper leaking again. I am at a loss for words.
Old Apr 5, 2018 | 06:07 PM
redvetracr's Avatar
redvetracr
using dot 3, 4, or 5 silicone ?
Old Apr 5, 2018 | 06:17 PM
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default huh
Is it a "new", "jobber rebuit", "home rebuilt", "rattle can rebuilt"? Gotta kinda know some history.
HeadsU.P.'s Avatar
HeadsU.P.
Dot 5 voids warranty.
Old Apr 5, 2018 | 06:59 PM
The Punisher
Dot 3 home rebuild
Old Apr 5, 2018 | 07:47 PM
HeadsU.P.'s Avatar
HeadsU.P.
There are four places where there could be a leak:
Bleeder screw
Piston seals
"O" ring between the halves.
Brakeline connection and/or plug.
Which one do you have?
Old Apr 5, 2018 | 08:44 PM
LT-1 kid's Avatar
LT-1 kid
# 5 , the one that makes a puddle on the floor,
Old Apr 5, 2018 | 10:33 PM
The Punisher
Bleeder screw
Piston seals
Piston seals
Old Apr 5, 2018 | 10:38 PM
Big2Bird's Avatar
Big2Bird
Piston seals
Maybe the bore on that one is out of spec.
Old Apr 6, 2018 | 06:35 AM
The Punisher
Thats possible it started out as a store bought rebuild with lip seals. Leaked after a year. I bought o-ring conversion kit lasted 3 years. I think its a conspiracy caused by wilwood trying to get me to upgrade
Old Apr 6, 2018 | 09:18 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Stainless
Have the cores been sleeved in stainless steel? If so, are they Delco Moraine calipers? I have had O-ring pistons on my 68 for 15 years, no problem. Jerry
Old Apr 6, 2018 | 10:21 AM
68-427Rich's Avatar
68-427Rich
Lonestar lip seal calipers. Done.
Old Apr 6, 2018 | 11:00 AM
Syl1953's Avatar
Syl1953
How often is the car driven? Little or no use is hard on all types of calipers.
Old Apr 6, 2018 | 12:49 PM
carriljc's Avatar
carriljc
I went to the Wilwoods ~5.5 years ago after dealing with stock calipers and rebuilds for ~20 years. They have been wonderful. Haven't touched them since - even though I should probably go bleed them for brake fluid change purposes.
Old Apr 6, 2018 | 01:21 PM
The Punisher
She sits from November to April. I try to go out to the garage about every 6 weeks and start and run her for about a 1/2 hour and pump the brakes a couple of times.
Old Apr 6, 2018 | 01:23 PM
The Punisher
Yes and yes
Old Apr 6, 2018 | 03:40 PM
carriljc's Avatar
carriljc
Well, I recommend the Wilwoods just because I quit having a those 2 decades worth of problems. A bit expensive, but I bought them on a group buy from this site so saved a little. The one thing that would make them better was if they made a combo-parking brake caliper for the rear. I asked them about that that(since they have a kit for other vehicles) but they did not(years ago) make that for the C-3 corvette--- that would be optimum just to get rid of that stock crappy parking brake.
To Brake caliper leak again
Old Apr 6, 2018 | 03:57 PM
The Punisher
Oh I hear you on the parking brake thing. I am still trying to adjust those to work properly. I think it would be easier just to pull out a wheel chock when parking on an incline
Old Apr 6, 2018 | 08:12 PM
Todd TCE's Avatar
Todd TCE
Supporting Vendor
Could be....
For about a G I can help you eliminate that problem on all four corners.
__________________
TCE
Your one stop...for Wilwood Brakes!
480.967.7901
Old Apr 6, 2018 | 08:50 PM
jb78L-82's Avatar
jb78L-82
Could be many of the items already mentioned. I will say this that the O ring calipers are no guarantee that calipers will not leak. Myself and others have lip seal SS calipers that do not leak after YEARS of being on the car and no, I do not go out to the car and step on the pedal every few weeks in the winter to actuate the pistons. My VBP SS lip seal calipers have been on my car since 1985 and other than changing the brake fluid with Dot3/4 every 4-5 years, I do nothing to my brakes and have never had a leak. Car sits 99.99% of the time. Usually, a leaking caliper is caused by some other issues OR a wheel bearing in the rear out of spec.............Could it be a defective caliper not rebuilt properly? Sure, anything is possible...................
