BBC Advice Needed
Old Apr 9, 2018 | 09:46 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Originally Posted by ajrothm
Good solid plan...keep the 049s.
3/8s rods with good rod bolts are fine. You can easily hold 600hp+ on 3/8” rods.
Just make sure to get the pistons sized correctly so your piston to wall clearance is tight....(since your block has already been bored and honed.)
You should have a nice combo....
SO for the pistons, I'm not sure what to do. I've settled on some KBs. So do I call summit and give them the exact bore of each hole? Or simply purchase a set of .030 and then match each piston as best as possible?
Also, when you say to balance the new pistons, you are talking to match them to lowest weight, but the rotating assy would still be externally balanced?
Thanks for your assistance.
-pappy
Old Apr 9, 2018 | 09:59 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Yes....as stated...keep the 049's.....put pistons and cam in this. Rebalance as needed.
As far as pistons go.....measure the bore exactly and pick pistons from that......KB's go in tight.....4032 alloy forged go in tighter than 2618 do......I.E. 4.280 bore BBC will have .005 for 4032 for piston to wall....2618 will have around .007......this is the difference between an SRP and a JE race piece.
Jebby
Old Apr 9, 2018 | 02:59 PM
ajrothm's Avatar
ajrothm
Jebby
Yeah.... what he ^^^ said....
The closer to .005" you can stay, the less oil consumption and ring flutter there will be.
Old Apr 9, 2018 | 03:26 PM
L88Plus's Avatar
L88Plus
Clearance should be built into the piston. If you have a block honed at 4.030, the piston should fit the bore with perfect clearance. If you go with KB Hypers, you'll need to pay particular attention to ring gaps.
I've used SpeedPro for years without issue, all the KB's I've messed with were bricks, way heavy.
Old Apr 10, 2018 | 02:22 PM
CheezMoe's Avatar
CheezMoe
Ok, so I'm going with 30cc dome SpeedPro and .050 gasket, .035 deck for a result of 10.10:1 static and 7.8:1 dynamic and .085 quench. Sound good?
Thanks again for the help.
Old Apr 10, 2018 | 02:55 PM
ajrothm's Avatar
ajrothm
How do you know what the deck height is gonna be?
If you are putting new pistons in it, you will be final honing the cylinders to size. At that point, you may as well zero deck the block. That will true everything up and get your quench back to an acceptable range of .038-.045" depending on the head gasket you use.
However with 30 cc domes, my logic may create a bit too much compression.
Normally you order pistons while machining the block so you know exactly which pistons you need.
Old Apr 10, 2018 | 09:50 PM
CheezMoe's Avatar
CheezMoe
Edit: Ok I figured out that .085 quench is way too much. So if the deck is indeed .035 with the new pistons, can I get away with like a .010 head gasket? ...or should I plan to bite the bullet at that point?
The block has never been decked and the .035 was measured. The block has already been bored and I'm just planning to order a set of Speed Pros .030 from Summit and place on a best fit basis. I'm not planning on taking the crank out of it.
So I guess my question at this point is .085 too much quench? Will it cause any issues?
Old Apr 10, 2018 | 11:37 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
not removing the crank is asking for trouble. If you are changing pistons you will change the balance of the engine. You will need to get the crank, flywheel and balancer, re balanced for the new weight of the pistons, rods, bearings and rings combo.
i should also add 0.035 seems high for a deck height. Factory pistons are normally only 0.020 in the hole. The pistons you have now P5047 comes back to an Enginetech piston. They state their pistons have a lower compression height by 0.010-0.020 to help with blocks that have been decked. That is why what you have measured now is so deep in the hole. When you replace the pistons you will need a new measurement.
Old Apr 11, 2018 | 07:31 AM
derekderek's Avatar
derekderek
Also, some pistons RAISE the compression height to get closer to zero deck without taking much or any off reg deck surface. +.010 is common. And boy would that compression have been low with those pistons and chambers.
