Engine replaced '72 Lt 1 corvette
Old Apr 8, 2018 | 06:57 PM
H3SA's Avatar
H3SA
2nd Gear
Default Engine replaced '72 Lt 1 corvette
Engine was replaced in '72 LT 1 with 1995 crate motor by previous owner. Car has set up for at least 15 years. Would like to rebuild motor with original type cam and lifters. How does the crate motor 8 to 1 compression ratio affect performance? Is this compression ratio to low for this cam, also what are the original cam specs for the original camshaft?
Old Apr 8, 2018 | 07:21 PM
derekderek's Avatar
derekderek
So this crate motor ran for 7 years? Daily driver, or occasional use? also, how do you know the specs on this crate motor? Many were decent performance engines, not just bottom of barrel cast low compression smoggers...
Old Apr 8, 2018 | 08:17 PM
HeadsU.P.'s Avatar
HeadsU.P.
You will need to figure out the manufacturer of the engine, get some numbers off the passenger side front pad and go from there. I don't believe anyone on this forum can help with the engine & cam specs with only the year it was made. And yes, 8 to 1 CR is just awful.
Old Apr 9, 2018 | 08:31 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
the 70 had 11:1 compression, the 71/72 had 9:1 compression. Using the LT1 solid lifter cam will change the performance but you wont get the 330 HP that it once had without the higher compression piston and low volume head. You can change the heads as well and that would help a huge amount because the 8:1 compression probably has over 72cc of volume. I would find some low 60cc volume heads ( 62 or 64 cc). Newer heads will flow better as well which will boost HP. Try the bolt on stuff first before rebuilding the bottom end
You can go to the comp cams website or crane cams site and look for nostalgia muscle car/performance cams
http://www.teufert.net/corvette/corvette-cam-specs.htm
good luck
scott
Old Apr 9, 2018 | 01:51 PM
H3SA's Avatar
H3SA
2nd Gear
Default 72lt1
Thanks for all the info . Got some research to do.
Old Apr 9, 2018 | 02:50 PM
HeadsU.P.'s Avatar
HeadsU.P.
At this point, all you know is that its a 1995 crate engine. Could be a 350. Could be a 355. Could be a 400. Choose parts wisely.
Old Apr 9, 2018 | 04:28 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Put a modern cam in it. The LT-1 cam is 1969 technology.
Old Apr 10, 2018 | 12:38 AM
7T1vette's Avatar
7T1vette
Just my 2 cents:
If you are thinking about putting LT-1 parts in the crate engine because the car was an LT-1 car (when it had its original engine), forget it. With any other engine than the original, you might as well install modern/better technology if you are trying to increase performance. New aluminum heads, roller cam/lifters, appropriate pistons and headers/exhaust will give you the power you are looking for. And, you can configure the outside of the engine so that it still "looks" like an LT-1 engine.
Putting LT-1 parts inside a non-LT-1 block, does not an LT-1 make.
Old Apr 10, 2018 | 03:43 PM
F4Gary's Avatar
F4Gary
Originally Posted by 7T1vette
Just my 2 cents:
Old Apr 10, 2018 | 04:01 PM
Rescue Rogers
depends on your budget. roller cam will bump up the price over a grand more. Yes its nice but not necessary
Old Apr 11, 2018 | 07:16 AM
7T1vette's Avatar
7T1vette
Not necessary, maybe..... but there are enough problems reported here with rebuilds using flat tappets and getting early wear-outs that it would be "necessary" if I were rebuilding the engine for my Corvette.
The OP will do what he/she wants. I'm merely offering suggestions / advice.
Old Apr 11, 2018 | 08:36 AM
Rescue Rogers
good point, we just need to pay attention to the oil we use.
Old Apr 11, 2018 | 11:08 AM
cv67's Avatar
cv67
St. Jude Donor '05
Bump up your compression
Trick Flow makes a real nice aluminum heads that has the double humps cast into it. Paint them up noone would know
Upgrade to a modern SFT or HR cam youll look back and say LT What?
To Engine replaced '72 Lt 1 corvette
