Motor mounts (replace)
Old Oct 16, 2002 | 02:21 PM
TJRed76's Avatar
TJRed76
Default Motor mounts (replace)
I'm going to replace my motor mounts on my '76. It seems like no big deal when I look at it, but I tend to overlook potential problems until I run into them.
Are there any " oh S%^&" obstacles that I need to be aware of? :confused:
Old Oct 16, 2002 | 02:39 PM
redwingvette's Avatar
redwingvette
Default Re: Motor mounts (TJRed76)
There are three bolts that hold them on. One on each end and one at the bottom center which could be a real pain to get to with the motor still in the car. Depends on high you can lift the motor before the trans bell housing hits the fire wall.
Good luck
Old Oct 16, 2002 | 02:42 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
I have two new factory style CarQuest motor mounts new in the box. Send me your address and you can have them, just send me a check back for whatever the shipping was.
Old Oct 16, 2002 | 04:57 PM
Duke94's Avatar
Duke94
As I recall, the PS pump was in the way on the left side and required removal (or at least moved a bit). The right side is simple.
Old Oct 16, 2002 | 05:09 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: Motor mounts (Duke94)
I have been told there is usually no good reason to change them.
Old Oct 16, 2002 | 08:05 PM
Fastguy's Avatar
Fastguy
Default Re: Motor mounts (OHSIXX)
How about if you powershift, break both of them, blow the fan through the shroud and make the hood fly open on the 1-2 shift.:D They break all the time. The only thing that holds the motor in when they break is the exhaust.
[Modified by Fastguy, 7:06 PM 10/16/2002]
Old Oct 22, 2002 | 03:37 PM
TJRed76's Avatar
TJRed76
Default Re: Motor mounts (Fastguy)
Thanks Fastguy:
I'll IM you and give you my address.
This forum is the best! :cheers:
Old Oct 22, 2002 | 06:06 PM
GTR1999's Avatar
GTR1999
A lot of these have safeties built into them so when they break they don't go through the radiator,shroud,etc.
I just pulled the motor and the left mount fell to the floor - split in two!
I bought some Energy Suspension poly mounts to try.
Gary
Old Oct 22, 2002 | 08:05 PM
wcj's Avatar
wcj
unbolt the lower center bolt first before raising the engine. If there is a restrainer built into the mount bend it out of the way. they if the other two bolts are accesable at the time remove them also. in some instances of you have the existing ignition wire shields attached you will have to either remove them or at least move them out of the way. by the way if its the original setup your ignition wires run under the mounts. pull the center bolt betwen the chassis mount and the motor mount and jack up the engine using a block of wood on top of the jack and the oil pan. go slow and watch for any denting of the pan. on instillation you want to put the mount back on the engine with the top two bolts but just snug these bolts so that when you lower the engine back into the chassis you can shift the mount if necessary to install the lower bolt. hope this helps. wcj
Old Oct 23, 2002 | 01:54 AM
The Dude's Avatar
The Dude
Huh. I've done this, too. Replaced them with solids. Solids = Good. (For me.)
To Motor mounts (replace)
