Oil temps can exceed 250 degrees regardless of coolant temperature.
It all depends on load-
In my jet boat, the coolant never exceeds 160 degrees yet I need an oil cooler to keep the engine oil below 250 when I'm running flat out for more than a couple of minutes.
My BMW's oil temp sits at 245 all day long when driven hard or on the expressway but the coolant never exceeds 200.
Don't be fooled by coolant temps-
Oil temp is the true gauge on how hard your motor is working.
I agree. You don't want to know the oil temp in an air-cooled Harley Davidson engine.
The oil is splashing against some very hot pistons and connecting rods in water-cooled engines.....a cooling unit/even one with a built-in thermostat can't hurt.
Just start using full-synthetic oil and forget about engine heat being an issue. With 200*F coolant temps, your engine oil is unlikely to run much more than 230*F. But, for your 'peace of mind', synthetic oil is very comfortable up to 300*F.
C3 (and other Chevy) engines have run fine for decades with 200*F+ coolant and NO oil cooler. Unless you are doing a significant about of racing, you are 'imagining' a problem.
This. When I track my car (Old VW), the coolant temp stays where it needs to be, but the oil temp goes up a lot, and that's with a big oil cooler running M1 15W50. I can't imagine not running an oil cooler.
Get the adapter plate with a thermostat. The oil will only flow into the oil cooler as needed.
Somehow I got my cooler installed in the front of the condenser/radiator. Went with a 180 thermostatic sandwich adapter at the filter. I had to use a shorter oil filter as my headers are right next to the filter.
This morning I took her for an extended drive at speed. The cooler only cooled the engine oil down about 5 degrees. Not acceptable to me in our heat.
I'm purchasing a cooler with a fan now. I'll mount it on the spare tire carrier. Look for a new thread soon.
Your car's cooling system does not cool your engine oil directly-
It's a by product of it cooling the engine from the heat of combustion.
I think this is where folks are having challenges seeing how the two fluids can have vastly different temperatures.
Coolant keeps the block and heads cool and the only way your engine oil benefits from this cooling is by contact with the heads/block as it runs down to the pan.
The harder your motor works (or the higher the output and compression of the motor), the hotter the oil will become in relation to the coolant temp.
That is why most HP, turbocharged or truck engines will have a separate oil cooler-
The heat from load these engines generate cannot be kept in check with just the engine's cooling system.
Just my .02
Just my .02
This is correct^^^^.
81/82 C3's with the factory installed oil temp gauge routinely will run 250 degrees on the oil temp gauge at the 12 O'clock position on the gauge and 200 degrees water temp.
My 10 C6Z06 runs 210 water temp with 200 degree oil temp BUT it has a factory installed oil cooler................
