Help Emergency how much 🐎can a my C3 take
Old 04-16-2018, 09:46 PM
  #41
Opie the Animal
Opie the Animal's Avatar
Thank you all for your help I really appreciate it I'm 38 and barely got my dream car so I want to hook it up right driver forever and get buried with her C3 is the coolest car I've ever seen personally I don't think any other year Corvette cant even compare to this year and any car on Earth the shape is so insane
Old 04-17-2018, 02:25 PM
  #42
C3 Stroker
C3 Stroker's Avatar
Originally Posted by Opie the Animal
I just screenshot it everything you said right here and I'm going to get it done to my car so you said I could run about 500 horsies 🐎🐎🐎🐎🐎🐎
.....I'm still looking for the horsie key on my keyboard......
73racevette (04-19-2018)
Old 04-17-2018, 07:51 PM
  #43
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
If you put good halfshafts in it, the stock stuff will hold up for a little while.... I went 10.90s on a bone stock, 140k mile rear end/trailing arms etc etc. I wouldn't recommend it but....it didn't break.
If you are planning to dead hook 700hp and stay together, at a minimum you are gonna need to build a "super 10 bolt", do the 31 spline outer axles, good half shafts and drive shaft.... You're about $6k or so for that rear end/shaft setup. And even that may not last too long if your converter is real loose and hits hard... The posi unit will be the weak link then.
I don't think I'd push a Super 10 bolt faster then 1.4x 60's honestly.
I would go ahead and put the 700hp motor in now, just don't drag race it too much until you can afford to do the rest of the stuff.
The T400 will only need a basic rebuild and a shift kit to hold that power.
My engine made 657hp on an engine dyno, probably around 600hp in the car (smaller headers, no air turbine, and spinning accessories) but my Super 10 bolt has held it for about 100 passes on the track and COUNTLESS runs on the street... and my car is heavy...
Old 04-19-2018, 12:35 AM
  #44
suprspooky
suprspooky's Avatar
I've got 460 BBC 560hp peak/Avg 480 Tq in a 68 4spd 4.11, stock rear/trans/shafts. What tires to run and 60ft to expect?
Old 04-19-2018, 03:44 AM
  #45
ajrothm
ajrothm's Avatar
MT ET Street radials.... or ET Street bias plies since its a stick car.....The car is probably capable of 1.6-1.7 60's...... but odds are, it will break everything from the fly wheel back first.... Reality is, you'll probably go 1.8 60' on the first trip out... I recommend slipping the clutch and feeding it throttle.... Don't "pop" or "dump" the clutch or you'll need a ride home.
Old 04-19-2018, 09:21 AM
  #46
Chicago Bob
Chicago Bob's Avatar
I I I I I I don't think they make one.
Old 04-19-2018, 09:54 AM
  #47
lionelhutz
lionelhutz's Avatar
I still haven't come up with one good reason why the decision to spend $15k on a new engine is an emergency....
Old 04-21-2018, 12:26 PM
  #48
roscobbc
roscobbc's Avatar
Tax reasons? - that time of year when one perhaps needs to be a little bit 'inventive' with business receipts and invoices - like his van needs a new engine.................
Old 04-21-2018, 01:54 PM
  #49
caskiguy
Support Corvetteforum!
caskiguy's Avatar
Here:http://www.novak-adapt.com/knowledge...utomatic/th400
Quick Reply: Help Emergency how much 🐎can a my C3 take
