Wipers will not work.
Old Apr 19, 2018 | 10:30 PM
Ramirez1976's Avatar
Ramirez1976
Default Wipers will not work.
Wiper motor isn't starting when I turn it on, I have tested the wiper switch for continuity and it's good, what else could it be? I think the wire that connects the switch to the motor might be bad, how can I test this?
-Ben
Old Apr 20, 2018 | 07:40 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Look at willcox's site for more tips
Old Apr 20, 2018 | 01:35 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Go to this link, it's got all the wiper info there. Also, if the dash bezel center is broken at the thin area, you'll need to run a jumper ground wire from the wiper switch to one of the smaller screws that holds the gauges in place. The wiper switch must be grounded for the system to work and it picks up the ground from the dash bezel center through the temperature gauge ground. If your upper plate/bezel is broken you'll have grounding issues..
Willcox
http://repairs.willcoxcorvette.com/?yt=1976&s=wiper
To Wipers will not work.
