GEN light blinking
Old Apr 23, 2018 | 09:51 PM
C3 4ME's Avatar
C3 4ME
Default GEN light blinking
So, the wife and I took the 79 out for about a 200 mile round trip to a winery with a Corvette cruise in this past weekend, and as we neared home, I noticed the generator light randomly blinking for a split second with no consistency, just completely random as to when it happened. I also noticed the volt gauge dipping instantaneously for the same amount of time as the light blinked. We made it home with no problem, and the car started just fine a little while later when I went to pull it back in the garage. I didn't notice the lights dimming when this happened. Does this sound like the alternator might be going out? As a side note, it might have been doing it the entire trip, but I only noticed it at night. I doubt I would have seen it in the daylight if it were happening.
Old Apr 23, 2018 | 10:15 PM
REELAV8R's Avatar
REELAV8R
Sounds like brushes are just about worn out or a loose connection at the alternator.
Old Apr 23, 2018 | 10:25 PM
drwet's Avatar
drwet
Sounds like a bad connection to me.
Old Apr 23, 2018 | 11:26 PM
Big2Bird's Avatar
Big2Bird
Bubba spliced in a flasher.
Old Apr 24, 2018 | 02:11 AM
Antz81's Avatar
Antz81
When I had this problem on my 81 that's exactly what it was. The thread for the ground bolt was stripped.
Old Apr 24, 2018 | 06:46 AM
derekderek's Avatar
derekderek
Alternators rarely eat brushes. So few amps across them. A rotor, stator or diode usually dies dead, but that built-in regulator can get intermittant. Easy to replace too. Need a stiff pin bigger than a needle smaller than coat hanger to hold brushes in.
Old May 3, 2018 | 08:37 AM
C3 4ME's Avatar
C3 4ME
I've got the day off today, so was looking forward to taking the Vette out for some fun. I just went out to the garage and hit the key and nothing at all. NOTHING! I got out my multimeter and sure enough, the battery showed 0.0 volts. When we got home the other week, I stopped in the driveway to unload the car and turned it off after our hours long drive. It started right up a half hour later when I went to pull it in the garage, and this morning is the first time I've touched it since then. I've got the battery charging out of the car now, and will take it and have it tested. Then I plan to reinstall in and take the car to have the charging system checked. Will let ya'll know what I find out.
Old May 3, 2018 | 02:19 PM
C3 4ME's Avatar
C3 4ME
ok, I've had 2 different chains test the loose alternator a total of 4 times, and it tested good every time. The battery however would not take a charge. The most I could get after an hour on the charger was .8 volts. It was confirmed at the store that the battery was no good, so for now, I'm going to take the battery from my C10 which is interchangeable with the Vette and put it in the Vette and see what happens.
Old May 4, 2018 | 12:48 PM
lionelhutz's Avatar
lionelhutz
I recommend you test the car for an excessive parasitic draw since that might have been what killed the battery.
Old May 4, 2018 | 01:46 PM
73racevette's Avatar
73racevette
Typically the only way a battery will show 0.0 volts is that it is shorted or damaged inside. Sounds like your battery needs to be replaced. Take you battery down and have it load tested.
Old May 4, 2018 | 05:07 PM
C3 4ME's Avatar
C3 4ME
Ok, with a known good battery from my truck in the Vette, of course it started right up, but the GEN light was still flashing. Then, i got out on the interstate and it stayed on, and the volt gauge was just barely below half way. Strangely, as soon as I got off the interstate the gauge went back up, just over half way, but not quite as high as it normally reads. I drove straight to Advance Auto for a system check, and of course the voltmeter was reading right over halfway, and their test showed no fault. Now I need to try to catch the GEN light on/voltmeter showing under half to have it tested. I'm thinking the alternator is dying slowly, because it seems to be getting worse each time I drive.
Old May 4, 2018 | 05:59 PM
73racevette
sounds like a short, or something as simple as a loose wire on the back of the alternator.
What is the battery voltage when checking across the terminals while it is running? If it is below 14 volts, your alternator or possibly your voltage regulator is not working properly. It should be 14.3 volts or so when running.
If it is below this, your battery is fine and something either in the wiring or the alternator itself is not working. After this, check the voltage as it leaves the alternator while it is running. It should be the 14.3 Volts. If not, then the wiring from the alternator to the battery is probably fine and it is the alternator.
Old May 5, 2018 | 08:19 AM
LenWoodruff's Avatar
LenWoodruff
I had a similar problem on my 78 a few years back. It was the flexible PCB board in the center gauge panel.
To GEN light blinking
