Timing a friends BBC 496 Stroker
Old Apr 26, 2018 | 03:32 PM
Bloodzone's Avatar
Bloodzone
Default Timing a friends BBC 496 Stroker
HEI on ported vacuum with this cam
https://www.summitracing.com/parts/cca-11-208-3
What would be a good number for total timing without Vac can connected? I've read as much as 40 for BBs. Should we start with 36 and go up till it pings?
I just want to set it and let initial fall where it may for right now.
BTW: It is set at zero initial atm for some reason. Guess how its running!
Old Apr 27, 2018 | 10:22 AM
ajrothm's Avatar
ajrothm
It really depends on the whole engine combo (compression, head material, cam specs etc) and how efficient it is.... I would NOT go over 36* though...
I run my 496 at 32-33* locked out, with a 4.5* of vac advance...
So 32* all the time, 36-37* at cruise with vacuum. No pinging with 10.0-1 compression, iron heads, 93 octane. I picked up knock on the dyno at 34*....
On all my other mild 454s I run 36* WOT and 10* vac advance....so 46* at cruise.
Depending on the curve in the distributor, you ideally want 15-16* initial at least, and then 36* all in by 3000...Then plug your vac advance in and limit its travel to give you a LITTLE more.
