NOS Power Steering Control Valve
My power steering control valve is leaking pretty badly. I have heard numerous horror stories about rebuilt and new valves leaking. I have the opportunity to buy a 32 year old NOS GM valve. Some of the paint is worn off and the rubber boot around the bolt stud looks to have some cracking. Would the old OEM valve be better than a current new or rebuilt unit?
I don't like changing parts twice. I always go new if possible.
You might also research rebuilding your original unit yourself. I believe Wilcox has a good video and the parts are fairly cheap.
Starting off with an NOS valve is way better than rolling the dice on some 40 year old rebuilt (how many times?) piece from a vendor.
Just my .02
Elm
In any event, it works now. So, if you carefully take it apart (not brain surgery, I assure you) and keep the correct order and orientation of all the parts, you can simply swap out the 'wear' type parts and put it back together. There are repair papers available on how to do this work...if you have the basic skill set to do it.
"New" rebuilds are assembled by untrained and unskilled help (in most cases), so stay away from "rebuilt" assemblies. NOS control valve has very old rubber stuff inside; I would not take a chance on it working.
If you can't do this work on your (good) valve, farm the rebuild out to someone you know who CAN do it. If you clean it all up ahead of time and provide the rebuild kit, that job will only take a couple of hours...MAX. If the person has past experience doing it, should take about 30 minutes.
$250 is too much for that unit. You can do it yourself with satisfying results. (For a few yrs anyway).
The quality level of these rebuilds is very questionable...just from the many incidents reported on this Forum--some having multiple defective "new" rebuilt control valves.
I stand by the comments made in my previous post.
don't get me going on caliper rebuild sets, power steering seals rebuild sets, hydraulic jack rebuild seal sets that leak from day one.
so my best advice is to use tried and true rebuild kits. but don't ask me where to find them. that's a crap shoot too..
As long as its a component which I feel comfortable taking apart and rebuilding myself, and the kits for rebuild are available, that's what I'll be doing. I don't want to take the risk of having to "do rework" on a faulty product after I've assembled it to the car!
But, some folks have done this two or three times, because nothing they've bought works like it should. The really critical aspects of rebuilding this control valve are:1. cleaning the parts really well
2. not damaging anything as you take it apart
3. keeping the individual parts in the correct order and orientation for reassembly
4. being careful to not damage anything during reassembly
5. keeping the outside clean so that debris cannot affect the rebuilt assembly.
Those are things that I can do BETTER that any worker at a rebuilder....because it's MINE and I want it to work!
Buy the rebuild kit, take your time and follow the video anyone can rebuild their own valve. It's really that simple....
Willcox
Power Steering Cylinder Rebuid video
