any transmission builders here?
Old Apr 30, 2018 | 06:52 PM
oldgto's Avatar
oldgto
Default any transmission builders here?
We rebuilt our 1971 TH400 with the help of a great "How to" book full of pictures, and a new kit with seals, rings, & clutches. Now we`re having an issue getting input shaft end play adjusted. Every time we install the pump & torque it to the recommended 18 pounds, it locks up, and the tail shaft won`t turn. (However, the tail shaft will turn with the pump in, but not tightened down). We`ve tried several different sizes of thrust washers, with the same results. Do we need to go back in and check the end play adjustment between the clutch packs? And if so, where do we find the recommended specs at those intervals?
Old Apr 30, 2018 | 10:29 PM
TOM B1's Avatar
TOM B1
Try this
https://www.sonnax.com/tech_resource...-train-failure
Old May 1, 2018 | 12:22 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Are you sure the hubs dropped down through all the clutches?
JIM
Old May 1, 2018 | 10:37 AM
TimAT's Avatar
TimAT
JIM
That's the usual cause- one of the clutch plates is not engaged in the spline on the hub. Easy to do.
Old May 1, 2018 | 04:47 PM
oldgto's Avatar
oldgto
THANK YOU gentlemen! We will check the link, and re-check the clutch pacs.
To any transmission builders here?
