81 rear wheel bearings
Old Apr 30, 2018 | 09:46 PM
2tone81's Avatar
2tone81
Default 81 rear wheel bearings
Right rear wheel bearings went out this weekend. From what I read It’s best to send them out to be set up properly. My questions then are do I need the spindle knocker tool to disassemble, how far do you take apart and what all gets sent in, who’s the preferred rebuilders. I was thinking Willcox ,but open to suggestions.
Old Apr 30, 2018 | 09:53 PM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
I did this myself but if I was sending them out I would send the whole trailing arm assembly complete!
Old Apr 30, 2018 | 10:06 PM
Peterbuilt's Avatar
Peterbuilt
Default Cheap special knocker tool.
Take the nut off and bring to home depot or lowes and find a bolt that fits the nut and get a 'pipe cap' to match.
Bring it home and hammer away.
I agree, send the whole trailing arm away.
Old May 1, 2018 | 09:08 AM
drwet's Avatar
drwet
Remove the complete trailing arm assemblies and send them off for rebuilding. Van Steel comes highly recommended. You don't need any special tools, although you may need a sawzall to get the trailing arm bolts out if they're badly rusted.
Old May 1, 2018 | 09:13 AM
jim-81's Avatar
jim-81
Depending on if they have ever been removed or not and how rusty and what not everything is down there it could be 'not too bad' or 'a f***ing b*tch' to get them off. If the strut mount is difficult I would buy the strut rod removal 'nut'. Guys say that a pipe plug will work too, never tried that. The removal nut is around $18 from the Corvette venders. That's the strut mount. The hinge pin can also be very difficult depending on what condition the shims are in. Mine was difficult and it wasn't even rusty. Most guys end up cutting through the shims and pivot pin with a sawzall, which is what I did. Lots of threads on here about this.
https://www.corvetteforum.com/forums...e-a-trick.html
Good luck!
Old May 1, 2018 | 09:14 AM
jim-81's Avatar
jim-81
Oh, and since you are in MI, I would recommend Bair's Corvette in Linesville, PA to rebuild the arms. They are always very nice to work with.
Old May 1, 2018 | 09:42 AM
drwet's Avatar
drwet
Good luck!
Absolutely correct. I forgot about the strut rod/shock mount. You will need the strut rod removal 'knock off tool'. It gives you something to beat on so you don't destroy the threads.
Old May 1, 2018 | 09:48 AM
drwet's Avatar
drwet
Many years ago I sent Bairs my original power steering control valve from my '66 to be rebuilt. They kept my original part and sent me some generic replacement. When I called them on it, they pretended they didn't know what I was talking about. You only get to do that to me once.
Old May 3, 2018 | 10:27 PM
2tone81's Avatar
2tone81
Why not just replace bearing and hub assembly, and leave the trailing arm alone?
To 81 rear wheel bearings
