Changing manifold gasket?
Old May 1, 2018 | 09:09 PM
Bhebert449's Avatar
Bhebert449
Default Changing manifold gasket?
i think I have an oil leak coming from the back side of my manifold gasket. I have noticed oil on on the back side top of the engine near the firewall.
How do do I confirm the source of the oil? If it is the manifold. Is the gasket difficult to change? It’s on a 1969 427 L68.
Old May 2, 2018 | 09:06 AM
Bhebert449's Avatar
Bhebert449
anyone?
Old May 2, 2018 | 09:20 AM
Street Rat's Avatar
Street Rat
The local auto parts store should have a kit with dye. Put the dye in the oil. The kit comes with a light to find the leak. The leak will be visible with the light.
Changing the gasket isn't that hard but the cooling system has to be drained.
Craig
Old May 2, 2018 | 12:09 PM
MelWff's Avatar
MelWff
Clean the area first to help localize the leak. It may be worth a try of running a bead of silicone gasket maker along the back edge and letting it cure for 24 hours and then recheck for the leak.
Old May 2, 2018 | 02:28 PM
Bhebert449's Avatar
Bhebert449
will the silicone prevent a leak? Wasn’t sure how much pressure gets built up where the intake manifold meets the engine block.
Old May 2, 2018 | 04:03 PM
MelWff's Avatar
MelWff
there is no positive pressure, actually if you have a PCV system most of the time there is negative pressure.
Old May 2, 2018 | 05:44 PM
Bhebert449's Avatar
Bhebert449
Is there a specific type of brand of silicone I should use?
Old May 2, 2018 | 05:49 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Permatex, high temp, RTV.
Old May 2, 2018 | 07:15 PM
DUB's Avatar
DUB
I agree that most of the time we want to see negative pressure.
Actually there is always positive pressure. The is no way the rings on the pistons are 100% efficient and not having blow by.
So...depending on how bad the engine is in regards to the blow by...IF the PCV can actually keep up with the positive pressure and make it a negative pressure...you should not worry.
One way to tell is to pull out your fresh air tube in the passenger valve cover and crank teh engine and put a dollar bill over the grommet. IF the dollar bill gets sucked to the grommet and when you go to slide the dollar bill off it...it is held there with tension. Your PVC is able to make this negative pressure....which is what you want.
IF the dollar bill gets blow away from the grommet and when you place your hand over the grommet you feel puffs of air...THAT is not good.
Keep in mind that the engine needs to be sealed up and no major areas for air to get into the engine. So...a bad gasket on an oil fill cap ...can allow air to be drawn into the engine and it is NOT filtered...a bad gasket on your oil dipstick... SO...just because the dollar bill did not get sucked to the grommet does not mean you have a problem becasue you have to make sure the engine is sealed up.
DUB
To Changing manifold gasket?
