How much timing for a 383?
Old May 1, 2018 | 11:35 PM
jr73's Avatar
jr73
Default How much timing for a 383?
What do these stroker motors like? I was thinking 10 degrees advance. Am I close?
Some stats;
full roller motor with .530 lift cam
750 double pumper
headers
Automatic trans
Old May 2, 2018 | 12:03 AM
corvetero's Avatar
corvetero
Some stats;
750 double pumper
headers
Automatic trans
You should provide more info about your cam
Old May 2, 2018 | 12:22 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Some stats;
750 double pumper
headers
Automatic trans
I'm at 20* initial on my 383, .612, .612 left.
Old May 2, 2018 | 07:26 AM
jr73's Avatar
jr73
270/278 duration
Old May 2, 2018 | 07:40 AM
cooper9811's Avatar
cooper9811
I ran a 383 with AFR 195 heads and a cam with that approximate duration and lift - As I recall, that engine seemed to like about 16 or 17 degrees initial, and had it all in about 34 or 35 degrees at 3000 or 3200RPM.
You may want to start with something a little conservative and adjust a couple degrees at a time till you find what your engine likes. Every one is a little different.
Edit - I also ran manifold vacuum for timing advance (don't recall the spec on the can) but with initial and vacuum pulling in timing at idle, had about 30-ish degrees of advance at idle - it worked really well.
To How much timing for a 383?
