1982 corvette hasitares
Old May 5, 2018 | 11:55 PM
Malkhawam's Avatar
Malkhawam
1st Gear
Default 1982 corvette hasitares
1982 corvette hasitates
and pops after it warmed up
Old May 6, 2018 | 12:11 AM
grantv's Avatar
grantv
Move on to C3 tech...
Old May 6, 2018 | 11:08 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
check all of your vacuum lines? sounds like your car needs a tune up.
heres a starting point...after its warmed up the choke is no longer making the car richer.....try to figure out why its leaning out
Old May 6, 2018 | 05:59 PM
DUB's Avatar
DUB
With the short description of what is wrong..before anyone really gets into this. It would be wise to come back and tell us everything that you have or have NOT done to it.
Such as. If the car has been sitting for five years...and still has the old gas in it...no wonder why it is acting like it is.
So knowing as much as possible helps US help YOU.
This is a 1982 and there is no choke...it is fuel injected.
DUB
Old May 7, 2018 | 06:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
When was the last time it was tuned?
Old May 7, 2018 | 03:04 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
DUB
Also, if it's popping/backfiring are you setting a CEL (check engine light)? Does the light ever come on? If so, pull the codes and see what is going on. Like mentioned, we need more information what has happened to give you a better course of action.
To 1982 corvette hasitares
