I need some water pump schoolin'
Old May 7, 2018 | 04:19 PM
psykod's Avatar
psykod
Default I need some water pump schoolin'
I'm trying to figure out what water pump to buy for my 1974 l82 and there seems to be multiple options...I hate that. I see Short vs Long style and 5/8 vs 3/4 shaft.
Were there differences within the same year and is there an easy way to tell without pulling the pump?
I just want to get a new pump, nothing special, maybe hi-flow.
Old May 7, 2018 | 04:30 PM
Darinm's Avatar
Darinm
Unless something has changed from the original setup,definitely a short water pump. I believe the shaft is 3/4". When searching for a replacement, if you specify your year model corvette, most parts places will get you the proper one. No need to remove it until it's time to replace it.
I know others will chime in shortly.
Old May 7, 2018 | 04:50 PM
psykod's Avatar
psykod
Cool. I think you're right. I just get two selections when I go to oreillyauto.com and they are both short style with 3/4 inch shaft.
Old May 7, 2018 | 05:36 PM
Mooser's Avatar
Mooser
From Edelbrock cataloge
1969-70 350 Corvettes. Short Pilot = 5/8" Block to Flange = 5-5/8"
1971-82 S/B Corvettes. Short Pilot = 3/4" Block to Flange = 5-13/16"
1969-70 B/B Corvettes Short Pilot = 5/8" Block to Flange = 5-3/4"
1971-74 B/B Corvettes. Short Pilot = 3/4" Block to Flange = 5-3/4"
M
Old May 8, 2018 | 11:55 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I agree with short pump. Just pull the fan and measure the hole diameter best way to be sure
Old May 8, 2018 | 12:14 PM
MelWff's Avatar
MelWff
you appear to be in Texas, go for a better pump
https://www.flowkoolerwaterpumps.com...duct_info.html
Old May 8, 2018 | 12:33 PM
psykod's Avatar
psykod
Of course I see this after I've already bought one. I bought a Stewart hi-flow that cost more than that.
Old May 8, 2018 | 01:23 PM
Street Rat's Avatar
Street Rat
That's all I run on my motors is a Stewart pump. Convinced me with a pump that cooled a radical BB down.
Stick with what you bought.
To I need some water pump schoolin'
