Curb Weight
Old May 8, 2018 | 06:09 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Default Curb Weight
I had the chance to get my 77 weighed today......so with almost a full tank of gas, and me sitting in the car, the weight was 3420 lbs....subtract my 180 pounds out, and that makes curb weight 3240 lbs....about 300 lbs less than factory advertised curb weight.
I am very happy with that number. How did I get there? -
- Aluminum Dewitts radiator
- Aluminum AFR heads
- Aluminum Edelbrock RPM intake
- Aluminum Edelbrock water pump
- StainlessWorks stainless headers and exhaust system
- No Emissions garbage
- No Airconditioning
- No heater hoses
- No radio or antenna
- No power steering (factory manual steering)
- Original Borg 4 speed (less weight than automatic transmission and associated coolers, hoses, etc.)
- Aluminum YJ8 reproduction wheels - much lighter than Rallye wheels
- VBP Composite rear spring
- Otherwise, the car is in stock configuration, including spare tire carrier (tire only, no wheel).
Power to weight baby!
Old May 8, 2018 | 06:17 PM
jb78L-82's Avatar
jb78L-82
That is a great number for weight!
I am in the same boat as you with my 78 with many of the same weight saving components:
AFR Aluminum Heads
Dewitts Aluminum radiator
Stewart Stage 2 aluminum water pump
Long Tube Ceramic coated Stainless Steel headers
No AC Compressor
No emissions Hardware including AIR pump and hardware, cat, etc
4 Speed Tranny
SLP 17 inch rims/tires-Lighter than the 255/60/15 and OEM aluminum Rims
80 Clam Shell Fully bolstered Seats-Much lighter than the Stock 78 seats
No Spare tire or spare tire carrier
I am guessing about 3150-3200 for my 78.
Old May 8, 2018 | 08:59 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
- No heater hoses
- Otherwise, the car is in stock configuration, including spare tire carrier.
Nice job. That lower weight also helps when it's time to slow down for the corners.
I've had mine on a diet for the past several years too. I finally learned how to weld aluminum, so in addition to most of the items you mentioned above, I managed to swap out several steel items for fabricated aluminum substitutes.
Keep us updated on future weight reductions.
Old May 9, 2018 | 02:13 PM
The Money Pit's Avatar
The Money Pit
I weighed my 80 years ago, and with similar mods had 3250 or there about. Since then I've put an L88 hood on, which is quite a bit lighter than stock, and my rear tires are thinner.....
Old May 9, 2018 | 06:44 PM
theandies's Avatar
theandies
Nice job.
My '71 Convertible without power anything and with similar mods as you as far as changing everything that was cast iron over to aluminum I weighed in at the garbage dump scales a 2997! Woot! I was trying to just get below 3000. Did I mention I took out the spare tire and tire carrier, no jack etc? That should shave off close to 50lbs give or take a few.
Of course I started at a significant weight advantage than you not having the 5mph crash bars front and rear and mine being a base car without any options. The shipping weight of my car was 3167
Old May 9, 2018 | 08:06 PM
Shovels and Vettes
Default 77
Originally Posted by theandies
Nice job.
I definitely started out at a disadvantage over earlier cars. The heavier crash protection stuff is something I will keep. Even the fire shield over the gas tank is heavy steel, but I thought it was worth keeping. Of course 77 has the big steel waffle panel in the doors for side crash protection. These safety features are worth it to me.
I am pretty happy I knocked off 300 plus pounds. As for more, I am considering dumping power brakes, but not sure yet, mostly because of the scale of the job, not because I like them. I think I would prefer manual brakes to go with the heavy clutch and manual steering.
More subtle weight reduction includes fact I have no windshield washer tank or hose, no wheel in my spare tire carrier (I hate the empty look without the carrier), no options at all when it comes to silly early model gadgets like fiberoptics and windshield wiper doors or headlight washers, no power windows, no electric window heat defrosters, no Astro ventilation, no hood insulation, no radio, radio wiring or radio speakers, no "deluxe" door panel carpet.
So, its about as light as its going to get.
Old May 9, 2018 | 09:03 PM
69427's Avatar
69427
If someone will refresh my memory here, please. An item I swapped out to pull several pounds off my '69 was the cast iron steering column support bracket (11#, IIRC). The later stamped steel support piece was about 4#. I don't remember which model year in the 70s that the change was made to the lighter bracket. Anyone recall when the change was made?
Old May 9, 2018 | 09:12 PM
MCMLXIX's Avatar
MCMLXIX
I think the stamped steering bracket started in 1975.
Old May 9, 2018 | 09:26 PM
69ttop502's Avatar
69ttop502
That’s interesting and something I didn’t know! Mine is apart now so would be a good time to hunt down a later bracket. Thanks!
Bill
Old May 9, 2018 | 09:55 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
That seems heavy to me for an early model C3. By 82 the C3s put on more pounds and with a half tank of gas and me in it, mine weighs in at 3350 according to the scale which I thought was awesome. I have similar things like yours, but no tire carrier now and pwr steering. Book says mine is 3342 stock. The book says a 77 weighs in at 3541 stock.
Old May 10, 2018 | 06:58 AM
Shovels and Vettes
If you are referring to my 77, me being the OP, you are correct that book weight is 3541, so I am 300 lbs lighter than that, so not sure what your comment means about heavy. Comparing to an 82 is a different frame, etc. and in fact I believe book weight on 82 is lighter than 77, as you said, but about 200 lbs - they supposedly lightened the frame, the diff mounts lighter, etc.....CAFE requirements.
Anyways, I am very happy to have shaved off 10% weight, but I doubt there is much more I am willing or able to do. With my pumped up engine, and reduced weight, I think the car is quick and for me, it just satisfying to have eliminated unnecessary weight.
Old May 10, 2018 | 09:30 AM
Backstop's Avatar
Backstop
You could lose another 20 pounds or more by switching to a mini AGM battery. I just did this two weeks ago, got the Braille 15-pound one, it was easy and not much more expensive than a good-quality normal battery.
Old May 10, 2018 | 12:04 PM
69427's Avatar
69427
Bill
Once you get that assembly out of the car and it's in your hands you'll be standing there shaking your head wondering what the heck was Duntov and crew thinking at the time, installing something like this in a Corvette.
I can only think that this must have been an incredibly cheap component taken from an early 60s impala or something.
Old May 10, 2018 | 12:13 PM
69427's Avatar
69427
I'm currently running a 16# battery in mine. I've got a thread in the Autocross/racing section asking for input from guys running the uber lightweight Lithium batteries. I keep hearing comments (elsewhere) ranging from "they work great" to "that's a fast way to burn down your Corvette". I want to keep taking weight out of my car, but I don't know what to think about these lithium batteries at the moment.
Old May 10, 2018 | 01:26 PM
jb78L-82's Avatar
jb78L-82
Anyways, I am very happy to have shaved off 10% weight, but I doubt there is much more I am willing or able to do. With my pumped up engine, and reduced weight, I think the car is quick and for me, it just satisfying to have eliminated unneces sary weight.
The 63-82 C2/C3 Frames are all the same, essentially. There has been some talk of the weight difference, but I don't think anyone has shown, conclusively, that there was a weight savings. The 80's were lighter by a couple hundred pounds mostly from the aluminum batwing suspension/Diff cradle and the fiberglass panels used in 80-82 were thinner , thus lighter. These changes shaved about 150lbs.
Old May 10, 2018 | 03:15 PM
Bikespace's Avatar
Bikespace
The N90 aluminum wheels of 80-82 saved 32 lbs over the YJ8 wheels of previous years. That is a not insignificant amount of unsprung weight, comparable to the savings of going from stock to Wilwood aluminum calipers.
Old May 10, 2018 | 03:44 PM
Shovels and Vettes
Default Frame
I have wondered about that too. I asked myself....what could they do? Use thinner steel? Doubtful. I agree with you, its all in the batwing and fiberglass.
To Curb Weight
Old May 10, 2018 | 03:46 PM
Shovels and Vettes
Default Wheels
Are you sure about that? I know the YJ8 wheels saved 40 lbs over the steel Rallye wheels, but I doubt N90 wheels could be another 32 lbs less than YJ8.... they are not that much different in design, a single back rib versus two??? Slots slightly different. But I could be wrong. Where did you find this information?
Old May 10, 2018 | 03:59 PM
Bikespace's Avatar
Bikespace
This Hemmings article has a reference. 8 lbs savings for each wheel.
https://www.hemmings.com/magazine/hmn/2012/02/Corvette-YJ8-Aluminum-Wheels/3708551.html
I have a set of each. I should weigh them sometime.
Old May 10, 2018 | 08:14 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
my understanding is that for fuel econ gm made every effort to lighten
late c3s.
