1982 corvette dead
Old May 10, 2018 | 10:07 AM
ceh_69's Avatar
ceh_69
Default 1982 corvette dead
when i bought the car it start fine, one day battery dead, went and got a new one now it wont even turn over not even a click charge battery see the interior lights on butt by the time i go to start lights are out you can see them go dim and go out and not even a click when turning the key Hmmmmmmmmm ? what is the box in front of battery box silver aluminium box ???? there was a kill switch on it took off and now going to try with out kill switch i think this vett going to be a pain with tons of problems that are going to be costly paid $9,000 anybody want it for that ??? i bet not
Old May 10, 2018 | 12:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ceh_69
...what is the box in front of battery box silver aluminium box?
The computer.
Do you have the assembly instruction manual (AIM) and shop manual for your car? Both could help you. Do you have an owner's manual?
Old May 10, 2018 | 07:08 PM
DUB's Avatar
DUB
I would like to help but when you type like you do. And do not use proper punctuation. It DOES make it hard the read what you are trying to tell us.
The advice given in POST#2 is priceless.
Buying a computer controlled fuel injected car without the proper tools and manuals for someone who does not know this stuff. Can make it an uphill battle. UNLESS that person WANTS to learn about this stuff. Hence...the books are needed. Because if it is schooling your are looking for here because you have no clue on what it is that you are looking at. Trying to educate you is possible but it can take a lot of time.
Do you have the tools and manuals to work on this car? If you DO get a service manual. Get a GM one from one of the major Corvette suppliers. Do not waste your time and money on a Haynes, Chilton or Mitchell manual. That is my opinion on that.
DUB
Old May 10, 2018 | 08:39 PM
terry82's Avatar
terry82
36 years old, you are going to have some issues.I would check behind passenger side motor valve cover .there is a group of wires that go into a connector goes bad .these wires go down to the starter .
Old May 10, 2018 | 10:08 PM
7t9l82's Avatar
7t9l82
Check the ground cable from the battery to the frame before you do anything.
Old May 10, 2018 | 10:13 PM
7t9l82's Avatar
7t9l82
The late model cars had aluminum ground cables that are notorious for corrosion build up. Get a jumper cable from the battery ground to a solid ground source and see what you have.
Old May 10, 2018 | 11:58 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
The computer.
THIS^^^ I think I may have mentioned this in a previous thread, not sure.
DUB
Words well said Dub. This is the truth especially if you are working on a C3 or older corvette. They do require a fair amount of maintenance to get them going in the right direction and then keeping them going.
To 1982 corvette dead
