496 coming together
Old May 11, 2018 | 01:28 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
Originally Posted by ajrothm
What intake are you going to run? Vic Jr?
Looks like you have a pretty stout combo in the works. Are you going to dyno it? Should make 700+ no problem...
i might take it to a chassis dyno. I was planning on the rpm Airgap and that’s what Chris ground my cam with in mind but I’m kinda wondering how to make a tunnel ram with dual quads look good on a corvette. I’ll definately keep my small block hood in case I want to go the other way with the intake. Ajrothm isn’t yours in the 700 range?
Old May 11, 2018 | 01:29 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
Originally Posted by Sigforty
That should spin up good. You will make some killer power.
im hoping so, I’ve heard a lot of good about chris’s Stuff so I’m optimistic.
Old May 11, 2018 | 01:39 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
It’s funny if you look at my first post titled smog 454 build, the parts I have listed that I wanted were like not even close to what I ended up with and a lot of you guys chimes in on that post giving me recommendations so this build was pretty inspired by just guys here on the forum. This is an awesome resource for information. Everyone I’ve used whether ordering parts or doing machine work (all but the block which is being done local) has been sourced here along with recommendations on cam size etc. anyways I think that’s pretty cool what we have here On this forum. Thanks for not letting me put the tiny cam I was going to put and the pancake intake manifold lol. AJ you’re the reason I went 496...I saw your video on YouTube racing I think it was a stang and I thought man....that’s how I want mine
Old May 11, 2018 | 01:45 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
Solid Roller 496 youre going to love it!! Nothing runs or sounds like a solid...youll never go back to a smaller motor/sbc. Once you experience that torque youre ruined for life!! Havent had a big block in years but havent forgotten how fun they are.
Part throttle pull, even rips with a tall gear its too much fun. No sbc will take the place of that. Had a 69 SS Chevelle with too big a cam, would still pull a tall gear real well no need for OD.
ya I just can’t wait to get that baby running. Big thing now is how to keep that baby cool
ajrothm's Avatar
ajrothm
No.. Mine made 657hp/670tq on an engine dyno... But that was using the air hat (+10) and 2"x3.5" shop headers...(+10).. Not to mention we made pulls at 120-130* water temp and 180-190* oil temps..these are the best of both worlds.... In reality, in the car it probably makes 625 or so before the accessories, exhaust etc...
Mine made 460 rwhp on a SuperFlow chasis dyno going through the T400, 3200 stall converter and heavy IRS stuff.
Old May 11, 2018 | 01:47 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
This will be fun to watch as I'm getting close to start building my 496.
so much fun! Make sure you give us some photos when you get going👍
Old May 11, 2018 | 01:49 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
I’ll be happy to do 625 when it’s all said and done👍
Old May 11, 2018 | 01:52 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
AJ what does your build consist of if you don’t mind refreshing my memory?
Old May 11, 2018 | 01:55 PM
ajrothm's Avatar
ajrothm
RPM Air gap, 1" open spacer and a 850-1000 cfm double pumper will get you there.... I bet you'll make way more then 625.....
My buddy's 498" with 10.5-1, Slick Rick ported Dart ovals, ported Vic Jr and a 1000HP, along with a straub 260/268* hyd roller made right at 700hp..... with a Dominator on an adaptor it made 718hp. In a second gen Camaro it went 10.0@133mph at 3600lbs in +1000' DA.
Old May 11, 2018 | 02:11 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
wow👍... that’s dang good. Mine will be right at 11:1 which at my elevation im told will be ok on 91...we will see. I want a dominator but I don’t think there is vacuum advance.
Old May 11, 2018 | 02:31 PM
gkull's Avatar
gkull
Your lifters just looked too tall for solids sorry, both of my engines have Crane Pro solids and they kept the metal at a minimum to make them lite weight
to ensure lifter oiling at lower rpm I used high volume pump with blocked off bypass. I keep my oil pressure at sub 75 psi hot by adjusting the oil weight. About half 10w30 vr1 with 20w50 VR1
Old May 11, 2018 | 03:09 PM
cv67's Avatar
cv67
St. Jude Donor '05
Sure look like hydraulics to me too. After seeing the pics again it says so right on the box.
Old May 11, 2018 | 03:20 PM
  #33
Muzzyzx7rr's Avatar
Muzzyzx7rr
well I will go check them out when I get home for sure now you guys got me nervous lol
Old May 11, 2018 | 03:29 PM
  #34
ajrothm's Avatar
ajrothm
With those cam specs, I bet its hydraulic. Even the instructions for install and adjusting in your pic says hydraulic.
Old May 11, 2018 | 03:55 PM
  #35
Muzzyzx7rr's Avatar
Muzzyzx7rr
why do the cam specs make make you think that AJ? I’m curious.
Old May 11, 2018 | 03:59 PM
  #36
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Its just some generic insert they put with the morels. Looking at the lifter neck down, they look like solids to me.
Old May 11, 2018 | 04:03 PM
  #37
Muzzyzx7rr's Avatar
Muzzyzx7rr
If they are hydraulic it’s wrong.
To 496 coming together
  #38
cv67's Avatar
cv67
St. Jude Donor '05
Look at the top, see if theres a plunger and a clip.
Old May 11, 2018 | 04:11 PM
  #39
ajrothm's Avatar
ajrothm
A 247/256* cam is pretty big for a hyd roller....and along the lines of what I think Chris would have spec'd for you..... A comparable cam in a solid roller would likely be 257/268* or so..... usually its roughly 10* more for a solid roller for comparable specs, this is due to the .02x" you lose from valve lash in a solid, vs. 0 lash in a hyd roller.
A 247 hyd roller will work pretty well for your combo, I'd run it for sure....
Since your receipt says "solid roller"./....I'd say its a solid roller.
Old May 11, 2018 | 04:12 PM
  #40
Muzzyzx7rr's Avatar
Muzzyzx7rr
thats what I’m doing as soon as I get home lol. I have a feeling that is a generic insert for Morrel lifters but we will find out
