Rebuilding headlamp assembly question
1. Is there any adjustments I should do with the assembly outside the car to get a rough placement? Things like the length of the rod on the actuator will be a pain to remove and adjust while in the car. Is there a starting setting point when putting them back together before I attache them back to the car?
2. There is a small screw on the front mount of each assembly. I think it was the outside front mount on each. It looks like a grounding screw but I dont see it referenced in the AIM. I ran all new wiring and taking a look at true wiring it looks like there is a ground at each headlight plug assembly, Here is a picture of the screw I’m talking about.
From setting the outer pivot bearings to the 'W' bracket...all of that is pointless. All fot hat is set when you get it in place.
As for that hex head bolt...I am assuming you have a 1968 or 1969 because you did not mention it. THAT bolt is used to hold the top of the OUTER park signal bracket.
DUB
Pat
One MAJOR adjustment many people may find causes them a problem when they think they are all done. And that adjustment is the adjustment that allows the door to go HIGH enough and LOCK not position so you can install your headlight bezel....and the front lower edge of the headlight bezel is just slightly below the front edge of the body in front of it.
This adjustment has nothing to do with the adjustment on your vacuum pod. The pod gets adjusted to it instead.
This adjustment I am referring to is done by the three bolts that hold the steel 'W' bracket onto the actuator support that you linkage is attached to.
Then the bent steel bracket that is bolted to the side of your headlight door is adjusted to when the headlight door is UP...it will not bounce or move and it can still LOCK in place.
DUB
When I do this I do not have the rod from the vacuum pod attached either. Often times the vacuum pod is NOT bolted to the headlight assembly during this fitting/adjustment procedure. I put it in later.
This is so I can get to that one bolt that is kinda blocked by the vacuum pod rod.
DUB
