Back fire
Old May 13, 2018 | 06:50 PM
martys76's Avatar
martys76
Default Back fire
changed intake manifold and carb
carb in street demon and edlbrock intake
when car is idling good and runs not bad but when i step on the gas it back fires. .it hesitates and the back fires any ideas timing is at 8 degease i am going to check to make sure my plug wires are corect
Old May 13, 2018 | 07:04 PM
HeadsU.P.'s Avatar
HeadsU.P.
I will throw some ideas at ya.
Lean condition?
Intake gasket not sealed 100% at the heads.
Carb base gasket not sealing.
Vacuum port fittings did not get thread sealant when installed.
Vacuum hoses to carb are loose.
Number 5 & 7 plug wires too close together.
Carb needs richer adjustments / tuning.
Old May 13, 2018 | 11:29 PM
lars's Avatar
lars
Backfire up through the carb is a sign of a lean condition, caused either by vacuum leaks, or by the carb being too lean (most likely). Carb lean condition can also be caused by a lean pump shot.
Contributing to this is your retarded timing. Get some timing into that thing!...
Lars
Old May 14, 2018 | 08:22 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
read Lars' paper on timing
Old May 14, 2018 | 01:30 PM
stingr69's Avatar
stingr69
Accelerator pump linkage adjustment needs to be checked. Any slack in the arm will cause this.
To Back fire
