1969 427 carburetor replacement
Old May 16, 2018 | 07:19 PM
Thelins's Avatar
Thelins
3rd Gear
Default 1969 427 carburetor replacement
I have a 1969 427 390 hp vet, and have had the carburetor rebuilt, but it still does not run right and is impossible to start. I would like to replace the carburetor. Any recommendations? Should I also replace the manifold? What combinations will fit under the hood?
Old May 16, 2018 | 07:26 PM
HeadsU.P.'s Avatar
HeadsU.P.
The poster has opened a (Holley) can of worms, 780 (cfm) worms to be exact. Let the (Edelbrock Performer intake) games begin.
Old May 16, 2018 | 09:15 PM
CanadaGrant's Avatar
CanadaGrant
If you have the original 7029215 Quadrajet it is worth quite a bit of money and with a proper rebuild will give you no problems. Find somebody who knows about Quadrajets and knows what they are doing. One of those carbs in pristine condition can go for $1500 or more so don't throw it away or the Snowflake aluminum intake either.
Old May 17, 2018 | 12:32 AM
7T1vette's Avatar
7T1vette
If you have the Q-Jet, get it rebuilt by Lars. Send him an e-mail (V8FastCars@msn.com) to request his services and find out costs & timing. He is the best and usually has decent turn-around time and very reasonable costs. You WILL be happy with the results and the car can remain in stock form.
Old May 17, 2018 | 07:57 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old May 17, 2018 | 08:37 AM
dmaxx3500's Avatar
dmaxx3500
are you sure its a carb problem?,has the car been tuned-up?,hows the fuel and filter?
Old May 17, 2018 | 09:25 PM
Thelins's Avatar
Thelins
3rd Gear
I just had a shop tune it up, gas is new. They rebuilt the carb, but not sure they did it correctly.
Old May 17, 2018 | 10:29 PM
CanadaGrant
If a shop just rebuilt the carb, tuned it up and it doesn't even start now let alone run properly where would you think the problem lies there....? See if you can find someone through the forum here in your area that has experience, the ability to work on it and a good reputation. Your ignition system and your carburetor are the most adjustable systems on your engine and both have to be set properly and in sync with each other. Don't throw parts at it like an aftermarket carburetor or intake manifold until you first know for a fact what is wrong with it.
Old May 18, 2018 | 07:05 AM
scrappy76's Avatar
scrappy76
How was the car running before the shop re-built it ? Next question, did you take it off and give it to them to rebuild it, or did you bring the car to them to do it?
Old May 20, 2018 | 12:07 AM
7T1vette's Avatar
7T1vette
If the car was running OK before they rebuilt the carb, don't go back to them. Send the carb to Lars so that he can review what was done and what needs to be done to make it right. He is very reasonable (for someone with his knowledge and skills) and will return a carb in better operating condition than when it was new on the car!
Do yourself a favor on this one...
To 1969 427 carburetor replacement
