Fuel line
Old May 20, 2018 | 06:56 PM
twinpack's Avatar
twinpack
Default Fuel line
I installed new fuel and vabor lines. Installed a new fuel pump. Now the question. What are you guys using the connect the hard fuel line to the fuel pump. I do have the rubber line from one of the vendors but my concern is todays fuel degrade rubber and I do not want to take a chance with a rubber fuel line. Unless the new lines are ok with todays fuels. Anyone know or have advice.
Old May 20, 2018 | 07:00 PM
JoeMinnesota's Avatar
JoeMinnesota
I use the fuel injection rated rubber line available virtually anywhere. Many say absolutely use the s-line available from Vette vendors for the main in to the pump. I used rubber but ran it thru a copper elbow so it would hold a turn and not kink (if you use 3/8 rubber from the hard line to the pump it usually kinks at the sharp turn, which will cause you problems.
Old May 22, 2018 | 12:05 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you should use the pre made S line. any other hose home made combination is sure to kink
To Fuel line
