Passenger window problem.
Old May 23, 2018 | 11:14 AM
Claudio Silvreti's Avatar
Claudio Silvreti
Default Passenger window problem.
Hello friends,
On my C3 '76 i have a little problem with the passenger window, this is going a bit too high.
And hits against the roof panel.
You can adjust it? How?
Thanks on advance.
Old May 23, 2018 | 11:20 AM
DB Cooper's Avatar
DB Cooper
Pull the door interior panel off, and the front and rear vertical guide rails have adjustable stops near the top of them... just a bolt and threaded steel plate through a slotted hole. those adjust not only the height, but the angle of the window in the up position.
I need to pull my passenger door panel and reposition mine a tad bit too.
Old May 23, 2018 | 11:26 AM
Claudio Silvreti
Thank you for the explanation, this will help me.
To Passenger window problem.
