Rear Plenum Drain
Old May 27, 2018 | 09:42 AM
1LE's Avatar
1LE
Default Rear Plenum Drain
Has any one replaced the hose on the rear plenum drain on a 74 ? What size hose is it and how do you get to the rivets? If that part is not available, what did you use?
Old May 27, 2018 | 09:47 AM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
I drilled the rivets. Hose I ordered from paragon. I'm sure other vendors have them too. You may need help holding things in place when you re rivet everything
Old May 27, 2018 | 10:26 AM
Mooser's Avatar
Mooser
The hoses have a flange on the one end that goes behind those shields, it's not just a straight hose.
As said, available from the regular vendors
M
Old May 27, 2018 | 10:32 AM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
https://www.paragoncorvette.com/p-35...ose-coupe.aspx
To Rear Plenum Drain
