Date coding alternator for ‘75
Old May 27, 2018 | 12:04 PM
Highlander1732's Avatar
Highlander1732
Default Date coding alternator for ‘75
“1102474 61A”
“5E8 - 12V NE?”
Thanks in advance: I just seapped my alternator out and suspect the one I took out is the original Delco-Remy unit. I have attached a picture that shows the last three digits as “474”. An older post I found related to a ‘64 owner faced with the same issue indicated that the last three digits are the week/year of manufacture. Does this hold true for the unit in my ‘75 as well? I know conventions can change but I would like to hang onto the original and have it rebuilt if it is original. Thanks again for your expertice and insight.
Old May 27, 2018 | 02:04 PM
BarryB72's Avatar
BarryB72
E. May
8...wait for it. ..8th day
Old May 27, 2018 | 05:53 PM
Highlander1732
Thanks very much!! I really appreciate the assist, as I would certainly not have know that. As it happens, my daughter’s birthday is 5/8!
Old May 30, 2018 | 06:41 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
How does the May 5th date match with the date of manufacture of your 1975? You can get at that a couple of ways if not sure, just ask. First place to look though is your manufacturers plate behind the drivers side door. Should be a month and day manufactured plate in there.
Always fun to sort out the facts and details.
Have fun with it.
David Howard
AllVettes4Me
Old May 30, 2018 | 06:10 PM
Highlander1732
Have fun with it.
David Howard
AllVettes4Me
Thanks for the response. While mostly original, the car has gone through a "restoration" in the past and the tank sticker is long gone. When you say "behind the door", is that the trim and paint tag on the drivers side below the A pillar?
Old May 30, 2018 | 07:58 PM
derekderek's Avatar
derekderek
Quite easy to install the new guts in your original cleaned-up cases.
Old May 31, 2018 | 08:12 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
That is the one. It contains your paint color information, your interior color code and style, and it contains your assembly date code as well.
Name:  09-07-09 1971 Arrives Home (45).JPG
Here is the date from my previous 1971. I27, April 27, 1971 born date.
Good luck with your research.
David
Old Jun 4, 2018 | 08:07 PM
Highlander1732
Default Thank you!
My tag teads I05 which corresponds to June 05, 1975? I guess the alternator could have been sitting on the shelf for a month?
To Date coding alternator for ‘75
