electrical problem
Old May 30, 2018 | 09:25 PM
venicesteve's Avatar
venicesteve
Cruising
Default electrical problem
I have a 1975 coupe I did some work behind dash when I put it back together the fusible link red wire going from fire wall loom to alternator put in new wire loom but fried fusible link again so wired in a 30 amp. circuit breaker starts runs 2 minuets pops breaker then will not start again opened all looms all wires look ok any suggestions
Old May 31, 2018 | 11:52 PM
venicesteve
Cruising
found problem all is good hope everyone is well wire on header could not see it heard it grounding out
