Does This Look Right?
Jun 2, 2018 | 11:20 AM
Jun 2, 2018 | 12:49 PM
You need to take the picture so we can see both gears and the marks that are on them to get a real answer...
Jun 2, 2018 | 01:55 PM
The problem is, the marks don't line up with the keyways. The circle mark is between two keyways.
Jun 2, 2018 | 02:22 PM
Looks right to me, rounded keyway slot to the O indicator mark = neutral timing
M
Jun 4, 2018 | 04:20 PM
2016 C3 of Year Finalist
the marks dont line up with the key way. Youu need to set the #1 piston at top dead center and line up the marks you want per the directions
Jun 4, 2018 | 04:40 PM
I guess I miss-read his question, I thought he meant which keyway to use for neutral timing, since he didn't show the cam gear I guessed he did align the "0" marks between the gears
Still using the rounded keyway for neutral timing, Here's an image
But since he hasn't responded since he asked I'll also guess he's moved on
M
Jun 4, 2018 | 06:49 PM
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
ok more importantly....so you don't wipe any lobes .....have you used lots of assembly lube and have you read how to break in the cam?
Jun 4, 2018 | 06:53 PM
he may be out working on it as well
Jun 6, 2018 | 11:39 AM
Yes, plenty of assembly lube, looking for oil with plenty of zinc before first start.
Jun 6, 2018 | 11:45 AM
Break in oil from your favorite race shop or, Walmart, mobil1 15w50. 5 gallon jug for $26
