Rocker arm adjustment problem
Old Jun 9, 2018 | 06:28 PM
caryb78's Avatar
caryb78
Default Rocker arm adjustment problem
I am installing new 1.5 rocker arms on a 383 in my 81 vet. Engine was running great. Removed old 1.5 ratio rockers and installed new ones. Set the lash and preload per the instructions. When I went to start it the engine spins over but no compression. Everything is turning but no compression. I assume the valves are not closing. This engine is very strong and est. about 425-450 hp. But I dont have the build sheet for it. Should I just reset the valves with zero lash and no extra 1/3 turn. It ran great on the old 1.5 rockers. I replaced them because they were from mixed vendors. Any ides appreciated.
Old Jun 9, 2018 | 07:53 PM
CanadaGrant's Avatar
CanadaGrant
What method did you use to determine that each cylinder was at top dead center on the compression stroke and how did you rotate the engine to adjust the valves on each cylinder? Did you follow the proper firing order when turning the engine over in 90 degree increments and adjusting each cylinder after rotating the engine? 18436572
Old Jun 9, 2018 | 08:37 PM
A8skyhawk's Avatar
A8skyhawk
I’d recommend you watch a couple youtube videos on rocker arm adjusting - I’m betting you did it mostly right but we’re just a little off on the cam positioning. I didn’t really get it until I read the procedure a few times and then watched someone do it.
Old Jun 9, 2018 | 11:05 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
I would keep trying to do it right, until it works....these are hydraulic lifters correct? do you have good feeling in your hands that you can feel the push rods engage the plunger while spinning the pushrod? when you finally feel the spin going away you hit the spot where the plunger is just starting to depress
I think Lars has a paper on adjusting the valves.
mark the base of the distributor at the bottom of the spark plug towers on the cap and make sure the rotor is pointing at one of the marks and adjust that cylinder.
Old Jun 10, 2018 | 01:20 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
For me it's easier to eliminate up and down movement of pushrod. And when I say that I mean VERY lightly. Lift pushrod up and down with light pressure and adjust until it JUST takes the play out. THEN adjust another 1/8-1/4 or whatever you feel like. Trying to do it with the "spin" method takes some feel...because often they will still spin with your fingers even though the lifter plunger is being depressed.
Make sure you adjust them in the correct order as mentioned.
JIM
Old Jun 10, 2018 | 02:52 AM
c3_dk's Avatar
c3_dk
Are you 100% sure, you was on TDC on cylinder 1 when you started adjusting?
Old Jun 10, 2018 | 07:36 AM
bjankuski's Avatar
bjankuski
There needs to be zero resistance on the pushrod when you set the preload. Rotate the pushrod until you feel the slightest drag and then set the 1/2:turn preload. You have yours set too tight.
Old Jun 10, 2018 | 07:37 AM
2mnyvets's Avatar
2mnyvets
Are you sure you have hydraulic lifters? When the engine cranks you say there is no compression. It sounds to me like you have solid lifters. Solid lifter get a .010" to .015" gap depending upon the cam. If you are tightening them 1/3 turn down, you are holding the valves off the seat with a solid lifter. The engine would not have much compression.
A second question: If the rockers were from different vendors, were they different ratios?
Old Jun 10, 2018 | 07:51 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
do you have the right rocker arms. If you didnt buy the the right length for the size springs, they could be hitting the side of the spring and you are getting false setting when you set the lash. It will screw everything up
Old Jun 10, 2018 | 02:18 PM
caryb78's Avatar
caryb78
Bumped the starter, did one cylinder at a time per the instructions that came with rocker arms, that worked all the other times i did this.
Thanks for the response
Old Jun 10, 2018 | 02:22 PM
caryb78's Avatar
caryb78
I just assumes they were hydraulic. Good point. Thanks
Old Jun 10, 2018 | 02:24 PM
caryb78's Avatar
caryb78
all the same, 1.5
Old Jun 10, 2018 | 02:26 PM
caryb78's Avatar
caryb78
Thanks, there not hitting. I pulled them off and also pulled pushrods to check for damage. all was ok. Thanks for repsonse
Old Jun 10, 2018 | 02:30 PM
caryb78's Avatar
caryb78
Started on #2 making sure valve was at base of lobe and zero lash. This was the suggested method from mfg. and one that I used numerous times before on different vet. Thank you for your response
Old Jun 10, 2018 | 02:33 PM
caryb78's Avatar
caryb78
I have done this several times on my other vet. But you are right I will look at you tube video. Thanks
Old Jun 10, 2018 | 05:02 PM
stingr69's Avatar
stingr69
No compression means the adjustment is too tight.
Loosen the nuts and retighten with a .002" feeler gauge. Set the nuts so they just barely drag the feeler gauge then remove the feeler and tighten a half turn more. Your car will build compression and it will run. Might need to snug them another 1/4 turn or so after that if it sounds at all like a sewing machine when it runs.
To Rocker arm adjustment problem
