2.5" N11 system on a C3
Old Jun 9, 2018 | 07:28 PM
aaronz28's Avatar
aaronz28
Default 2.5" N11 system on a C3
I'm looking to run a 2.5" system with N11 mufflers on a 1971.
Car currently is a 350/270hp 4speed - but i'm gonna rebuild the motor as a 1970 spec 11:1 LT1
planning to run 65 L76 exhaust manifolds which have the 2.5" outlet.
I was told that the C2 and C3 exhaust is different, yet the frame is the same - not quite sure what or why the the exhaust would be different other than the rectangle tips (which I would plan to use)
Any advice here?
Old Jun 9, 2018 | 07:56 PM
forman's Avatar
forman
i have n11 system ,, it sounds great .. i have the mcjacks shorty headers also ,, its not that loud
Old Jun 9, 2018 | 08:50 PM
7T1vette's Avatar
7T1vette
Most L-48 blocks have 2-bolt mains; LT-1 blocks are 4-bolt mains. You can build an L-48 block with LT-1 parts, but if you rev the engine to 6500+ rpms, I'm not sure it will hold together.
Other 'real' engine builders might want to weigh in on this.
Old Jun 9, 2018 | 10:58 PM
ezobens's Avatar
ezobens
I bought the C2 downpipes (2.5”) and the rest of the exhaust is a C3 2.5” system.
Fits perfectly.
Old Jun 10, 2018 | 04:40 PM
SIXTYTWO's Avatar
SIXTYTWO
Any advice here?
I used the 2 1/2" off road system with welded mufflers from Corvette Central . It has a nice tone, not too loud or raspy so you can hear the radio . Wide open throttle sounds great. Pretty close to the factory off road as I remember. Corvette Central had a fourth of July sale last year, the system was discounted and shipping was free.
Old Jun 10, 2018 | 06:55 PM
VERYSOON's Avatar
VERYSOON
The N11 system from CC bolts right up to a stock manifold which is 2" on a 1969 350. From that point on the system is 2.5". I really like it. You can really hear that qjet howl!!
VERYSOON
Old Jun 10, 2018 | 08:38 PM
twinpack's Avatar
twinpack
Default Exhaust
I've been restoring a 68 and used Hooker Competition headers paint. I bought CC 2 1/2" intermediate pipes and N11 mufflers. I had the intermediate extentions to connect to the headers made at a local mffler shop for $150.00. I had the whole system ceramic coated inside and out. The whole system installed pretty routine. Fit the frame and factory hangers.
Old Jun 11, 2018 | 03:20 PM
aaronz28's Avatar
aaronz28
cool thanks all.
I"m gonna go with the Gardner LT1 system which they'll build with 2.5" headpipes, then I can use 65 L76 manifolds - and that should help it breath a little better than the 2" manifold
Cheers
Old Jun 11, 2018 | 11:05 PM
Duntov's Avatar
Duntov
I’m guessing you are aware that the factory tips were 2” ones, end non C2’s
To 2.5" N11 system on a C3
