1982 Corvette-Code 12 Problem
Old Jun 12, 2018 | 07:58 AM
biaggio's Avatar
biaggio
Default 1982 Corvette-Code 12 Problem
Hi,
I am picking up a code 12 when check engine light is on. The service manual indicates that the distributor spark tuning reference pulses which are generated by the pick up coil are not being received by the ECM. What does this mean and how do you fix it? The plugs, wires, distributor, cap, rotor and ignition coil were change 1200 miles ago. Thanks
Old Jun 12, 2018 | 08:25 AM
murphy0515's Avatar
murphy0515
4th Gear
Originally Posted by biaggio
Hi,
I would delete the error memory and wait to see what happens. If everything goes well, everything is fine!
Old Jun 12, 2018 | 12:47 PM
David Mc's Avatar
David Mc
Code 12 means there is no rpm signal. It is verification that the computer is up and running.
Code 12 is normal condition unless it is flashing code 12 while running.
Old Jun 12, 2018 | 01:24 PM
av81's Avatar
av81
Check the black connector (4wire) behind the distributor make sure it's plugged in if it is most likely the ignition module is bad if the check engine light stays on with a code 12.
Old Jun 12, 2018 | 05:51 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Hi,
What are you saying...you are getting a code 12 when you do a test and that's it OR you are getting a code 12 because the CEL is on while the engine running? If you are just testing, don't worry about it, it's normal like mentioned.
To 1982 Corvette-Code 12 Problem
