Speedometer Driven Gear (plastic)
Old Oct 20, 2002 | 05:33 AM
glen242's Avatar
glen242
Default Speedometer Driven Gear (plastic)
What is the correct number of teeth on the plastic gear for a '76 4-speed with a 3.55 rear axle? I am wondering if the GM dealer sold me the correct gear.
Old Oct 22, 2002 | 11:18 PM
Bill 70Coupe's Avatar
Bill 70Coupe
Default Re: Speedometer Driven Gear (glen242)
The correct part #3989919 it will have 19 teeth for a 76 4spd. 355 ratio with stock size tires and origional transmission. The origional tire size was G70/15, I think in a radial that is equal to a 235/70/15. If you are running bigger tires you would need to go with fewer teeth.
Bill
Old Oct 23, 2002 | 02:03 AM
glen242's Avatar
glen242
Default Re: Speedometer Driven Gear (Bill 70Coupe)
Thanks for the reply. He sold me a 21 tooth gear. I thought that was wrong. What I am using, tire wise, is 26" tires rather than the 27.4" stock size. I have a 3.36 rear and the calculators I have used say that this equates to a 3.55 rear using the stock tires.
To Speedometer Driven Gear (plastic)
