Post your dyno numbers and mods thread!
Old Jun 27, 2018 | 12:48 PM
SteveG75's Avatar
SteveG75
Chassis dyno when EFI was tuned.
496 Big block with custom 3x2 EFI running FAST XFI 2.05, 10:1 compression, cam in the 240 @ .050" range, Airwolf (ported Edelbrock RPM) heads
T-56 manual (close ratio)
3.73 12 bolt rear
Tuner said that the sidepipes with STS baffles were choking the car above 5500 rpm. I think the heads might be a bit too big as well put the intake was custom made/ported for the heads so swapping heads would require intake rework. So, for now, I just drive the heck out of it.
Old Jun 27, 2018 | 01:52 PM
Knerf's Avatar
Knerf
Originally Posted by mobird
Cool! What is the rest of the combo on that motor? Cam and heads?
350 to the tire from a basic 383 is respectable, especially though the IRS on the C3.
220 afr heads
crower solid roller 288R 112° advertised 288° 290° at .050 250° 252° lift .570" .584"
victor jr intake
qft 850
Old Jun 27, 2018 | 02:46 PM
wabco40's Avatar
wabco40
Originally Posted by scottjamison
That color is awesome!
Thanks. Its 2002 GM Electron blue.
Old Jun 27, 2018 | 02:51 PM
wabco40's Avatar
wabco40
Originally Posted by ezobens
Awesome numbers!
What heads are you running?
There Dart Pro1 heads on a World aluminium block.
Old Jun 27, 2018 | 04:47 PM
ajrothm's Avatar
ajrothm
3.73 12 bolt rear
Those side pipes are killing it for sure... There is 40-50hp right there... I wouldn't worry about the heads being too big.
Also, SuperFlow dynos read a bit lower then dyno jets...8-10% lower similar to a Mustang Dyno.... I also dynoed on a SF dyno and I was surprised how low my RWHP was compared to my crank HP...
Old Jun 27, 2018 | 07:41 PM
SteveG75's Avatar
SteveG75
But the wife loves the side pipes.....
I am running STS baffles. I may pull them over the summer and cut off the center cap to improve flow. However, the car is very mellow to drive with the top down at cruise and I don't want to lose that character.
Old Jun 27, 2018 | 08:36 PM
ajrothm's Avatar
ajrothm
Yep...I totally understand... I don't like a really loud car either.
On my Dad's 65' 396 car, we built some custom, stock appearing side pipes using Classic Chambered crimped mufflers with 2.5" ID.... It woke the car up a lot over the stock midyear side pipes but....it is pretty damn loud now while accelerating..... Sounds similar to the stock pipe sound, with the volume up to 10. Luckily I'm going deaf in it so I get used to it...
Old Jun 27, 2018 | 10:39 PM
ezobens's Avatar
ezobens
WOW!
That is a lot of aluminum!
I am way jealous. Very slick!
Old Jun 28, 2018 | 09:11 PM
71yellow454's Avatar
71yellow454
Horsepower/Torque @ RPM: 418.53@5900RPM 411.15@4800 Engine specs: LS3 Texas speed stage one cam 225/236 .629"/.615" Transmission: 6L80 Type of Dyno: Dynojet
