Post your dyno numbers and mods thread!
With that said, post up your C3 Corvette's dyno numbers! Let's try to keep the information accurate by following this format:
Horsepower/Torque @ RPM:
Engine specs: (displacement, heads, intake, cam, power adders, etc...)
Transmission: (Th400, T-10, T-56, 700r4, etc...)
Type of Dyno: (Dynojet, mustang, etc...)
Elevation: (Density altitude)
Any other relevant info:
Please keep this to DYNO PROVEN NUMBERS ONLY! No "well my combo is about the same as my buddies who made 9,000 hp". This is to give people a fairly accurate idea of what different combinations will make, so let's not muddy the waters with estimates please.
Ready....GO
496 BBC, Edelbrock E-Street Heads, Repo LS6 intake, Straub roller conversion .050” Duration 229/235, Lift .590/.559, LSA 107
Autogear M23W, the works. 3.36 Gears.
Not sure, not a Dyno jet.
Sea Level
Its actually out of the car now after 24k miles of HARD service...now for some updates, hoping for a bit more power on version 2.0....
ZZ4 with GM's LT4 HotCam & 1.6 rockers
Home ported heads with Manley race flow valves
Manley valve springs & retainers
AFR's rev kit
650 Demon Mech. Secondaries
Driveline
5 Spd Richmond Manual Trans
3.08 stock rearend
Performance
1/4 mile =12.8 sec at 108 mph
60' time = 1.9 sec
IMG 0789
465/465 engine went a bit too rich from about 2500 to 3500 rpm. Have since reduced fuel for this part of the map but haven’t had it on dyno.
427 small block, comp cams 280 hyd roller cam, fabricated efi manifold, 42lb injectors, Fast xfi ecu.
Legend 5 speed transmission. 3.9 rear gears.
Dyno is a Mainline hub Dyno.
350 to the tire from a basic 383 is respectable, especially though the IRS on the C3.
What heads are you running?
