74 Door lock problem
Old Oct 20, 2002 | 06:31 PM
fcoppola's Avatar
fcoppola
Default 74 Door lock problem
My drivers door is locked shut. It is a manual lock. Neither the key or the inner **** works. I can not get the door panel off. Is there a way to open the door?
I had just added a clip to fix the inoperable outer door handle, that worked and for some reason the door locked on my. I knew they didnt work but never locked it.
Also related when I take the door skin on, it has a little access panel to work on the lock. However I wanted to remove the door lock mechanism to grease and clean it. It does not fit through the hole. How do I take the door panel apart to get it out? The skin comes off easy but I need to remove the second layer so to speak. Any help would be appreciated. :confused:
