-69 wiper door again.
Jun 21, 2018 | 06:08 PM
I have a small problem with the wipers. When you turn wiper on you can hear clik sound but nothing happens.Door won't open.
When you pull switch below column, door will open and wipers work.Hoses are propably ok...
Any suggestions where problem might be(with the door).
....thanks and greetings from Finland!
Jun 22, 2018 | 08:08 AM
Cruise-In II Veteran
Check the solenoid on the rear of the tach.
Jun 22, 2018 | 04:00 PM
Jun 22, 2018 | 04:02 PM
Thanks, is it possible to fix?
Jun 22, 2018 | 07:09 PM
YES...that solenoid can be replaced. This is what it looks like even though it is out of stock.
https://willcoxcorvette.com/corvette...solenoid-68-72
DUB
Jun 23, 2018 | 02:35 PM
If it is the tach solenoid you could replace it or just take it apart and clean it up. That may or may not be the issue with the solenoid but it may save you a little money and it's easy to do. Just remember to ohm out the coil as if this is bad you'll need a new one.
Repair your wiper door solenoid
Jun 23, 2018 | 03:15 PM
I try to clean and fix it.Thanks.
Jun 23, 2018 | 07:06 PM
I agree that your wiring to the solenoid can be bad. So when you go to use it ti will not work.
DUB
