E85 Questions
Old Jun 25, 2018 | 02:05 PM
bence13_33's Avatar
bence13_33
Default E85 Questions
What all does switching an engine to run on E85 entail (I'm speaking of course about a carbureted V8)? Is it merely getting a carburetor that is set up properly for E85? From my understanding E85 has an octane rating of around 105 octane, up to what compression ratio would that roughly support? I understand there is dynamic and static compression, both of which I don't fully understand. Thanks for the help.
Old Jun 25, 2018 | 02:18 PM
ajrothm's Avatar
ajrothm
You will need a carb that is calibrated for E85 and uses all of the corrosion resistant parts and gaskets. E85 requires about 30% more fuel then gas, so there is a big difference in calibration for the carb. Also you'll need a GOOD fuel pump to feed it, especially if you are running a pretty serious engine. E85 is oxygenated so there is power to be gained from that, plus the ability to run more timing with the higher octane. Generally speaking on naturally aspirated engines, E85 is worth 20-30hp over pump gas. Also if you have a high compression engine, say 12.0-1, that you normally couldn't run on pump gas, you can on E85.
There is pros and cons to the stuff for sure. For me, on a naturally aspirated, pump gas engine, its not worth the hassle...both with the maintenance and the lack of travel range and availability,
Old Jun 25, 2018 | 04:47 PM
v2racing's Avatar
v2racing
I just went here: http://www.altfuelprices.com/stations/E85/Pennsylvania/ and found that there are 31 cities with 37 stations selling E85 in Pennsylvania. Here in Minnesota we have 279 cities with 442 stations selling it.
As Alan said, unless you have 12 to 1 or higher, It's not worth it, especially when you have so few stations in your state. If you have over 12 to 1 and are mostly racing the car, go for it. A lot of racers have switched because of cost of race gas and because E85 is less fussy on jetting, meaning that guys running index or bracket racing can be more consistent going from a hot afternoon to a cooler evening without have to rejet.
Mike
Old Jun 25, 2018 | 07:52 PM
bence13_33's Avatar
bence13_33
ajrothm:
That's pretty much my fear is that I switch to E85 and end up going for a drive and go to fill up and it is unavailable. I'm assuming that an engine burning E85 may run slightly cooler than an engine burning regular gas? I'm just kind of spit-balling ideas as I always do, it's always nice to get everyone's opinions on here (usually end up learning something new at the same time).
v2racing:
With the lack of availability, running 93 octane and adding octane booster may be the wiser route should I decide to go with higher compression.
Old Jun 25, 2018 | 09:26 PM
ajrothm's Avatar
ajrothm
ajrothm:
v2racing:
There is a chance your engine "could" run cooler, many report that as true, but I surely wouldn't convert to E85 in hopes of accomplishing that. Also, look at it this way, if your car gets 10 mpg now on gas, its going to get 7 mpg on E85. Another example is, if your cruise range is 200 miles per tank on gas, its gonna be 140 miles on E85.... So unless your engine is a max effort deal, its really not worth the hassle....Especially if the car sits for any period of time, the E85 will wreck the fuel system if it sits for more then a month or two...
If I was running a 900hp 565", I MAY think about E85.....and even then I probably wouldn't do it.
ON the new cars with Flex fuel systems, there is no downside to e85. You can run E85 when you wanna run it hard, go back to gas when you need some fuel economy or travel range, and the computer does it all for you, in that setup, it is worth doing.
Old Jun 26, 2018 | 06:52 PM
suprspooky's Avatar
suprspooky
As AJ point's out, it's really only worth the effort (mostly street driven Car) in an EFI setup that has a Flex Fuel Sensor (at least one of the Fast Sys. is capable) unless you have lots of stations in your driving area. I researched it a ton for my Jet Boat SBC winter project (Hilborn 8 stack EFI), I have an Accel DFI controller so I will have two Fuel/Timing Maps so I can switch between E85 and Gas. I had considered adjust-a-jet but that still doesn't help with air bleeds etc.
To E85 Questions
