Rogue hose line query
Old Jun 26, 2018 | 03:05 PM
Fenchy96's Avatar
Fenchy96
Cruising
Default Rogue hose line query
Who are you, line marked in green, and where ought you to be plugged in? Cuz you weren’t when I found you...
Old Jun 26, 2018 | 03:19 PM
JayRay's Avatar
JayRay
I believe it is for your headlight vacuum there should be a fitting on the back of your intake manifold behind your carb. If you have an automatic you will see another vac line that goes to your transmission, it should attach to the same fitting. See where the yellow arrow is.
Old Jun 26, 2018 | 06:15 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and Welcome!
Start at the manifold and go piece by piece:
http://www.corvette-101.com/vacuum.htm
Old Jun 26, 2018 | 07:04 PM
DUB's Avatar
DUB
Welcome to the forum.
The yellow arrow is pointing to it. The vacuum check valve that you have can work but with it being plastic. Do not be surprised if it fails . This design of vacuum check valve is what GM uses on the 1984-1996 Corvettes and I change them out a lot due to how they are made and they can leak badly where the two halves are joined together..
The one in the link below is what was used originally....for what ever this is worth to you. And it is made out of a pot metal / aluminum material.
https://willcoxcorvette.com/corvette...ck-valve-68-82
DUB
Old Jun 26, 2018 | 07:53 PM
Fenchy96's Avatar
Fenchy96
Cruising
Thanks!
To Rogue hose line query
